liner33 Posted February 26, 2013 Report Share Posted February 26, 2013 A mate gave me a set of these (4) bushes for the front camber on Skylines Now I'm thinking of fitting them myself and then getting the geo sorted The question is how to fit them as in what position do i set the hole , logically my gut is telling me 3 o'clock but i'm wondering if thats too much and i should be more like 1 o'clock or 5 o'clock , or should i just leave it to the chap that aligns it ?? This is the extent of the problem i'm trying to correct, which isnt really a priority due to the miles i do , i imagine the only downside will be increased wear on the shoulders Quote Link to comment Share on other sites More sharing options...
Tony Posted February 26, 2013 Report Share Posted February 26, 2013 What adjustment value does the peak of the bushing give? Quote Link to comment Share on other sites More sharing options...
liner33 Posted February 26, 2013 Author Report Share Posted February 26, 2013 I dont know they came with no paperwork Quote Link to comment Share on other sites More sharing options...
liner33 Posted February 26, 2013 Author Report Share Posted February 26, 2013 Actually a quick search and if the bsuhes are whiteline then is probably +/- 1 degree but these look a much better option http://www.elitetech.co.uk/uprlinks.htm Quote Link to comment Share on other sites More sharing options...
Tony Posted February 26, 2013 Report Share Posted February 26, 2013 Since they cant be moved once fitted it's a best guess what position, but it helps know what camber you have and how much it will adjust. Quote Link to comment Share on other sites More sharing options...
liner33 Posted March 4, 2013 Author Report Share Posted March 4, 2013 Unfortunately those arms I linked are not available so ive ordered these Depending on what you read they either give -/=.5 degrees or =/- 1 degree , coupled with the other bushes that should give me more than enough I removed the front wheel to clean it over the weekend and the inner edge of the tyre is looking a bit worn so sooner rather than later Quote Link to comment Share on other sites More sharing options...
liner33 Posted March 4, 2013 Author Report Share Posted March 4, 2013 The upper arm looks like this Quote Link to comment Share on other sites More sharing options...
Tony Posted March 4, 2013 Report Share Posted March 4, 2013 Sorry to read like a downer but i've never had any luck adjusting those type of correcter bushings? Quote Link to comment Share on other sites More sharing options...
liner33 Posted March 4, 2013 Author Report Share Posted March 4, 2013 Do you need to adjust them though by pushing the whole arm out wont they bring the stock adjusters into play again ??? Quote Link to comment Share on other sites More sharing options...
Tony Posted March 4, 2013 Report Share Posted March 4, 2013 Well yes that would work. Quote Link to comment Share on other sites More sharing options...
liner33 Posted March 4, 2013 Author Report Share Posted March 4, 2013 Correction , there are no stock adjusters Looks like fun and games , i dont like the aftermarket arms they are two piece Quote Link to comment Share on other sites More sharing options...
Tony Posted March 4, 2013 Report Share Posted March 4, 2013 Bugger...... Quote Link to comment Share on other sites More sharing options...
liner33 Posted March 9, 2013 Author Report Share Posted March 9, 2013 Already to go , going to tackle it next weekend Quote Link to comment Share on other sites More sharing options...
Tony Posted March 9, 2013 Report Share Posted March 9, 2013 Have you figured out what way your going to fit them? Quote Link to comment Share on other sites More sharing options...
liner33 Posted March 9, 2013 Author Report Share Posted March 9, 2013 Yes I think each gives .5 degrees and I need almost 1 full degree so ill fit each set to correct the negative camber I can put the magnetic gauge on the brake disc to get close to where it needs to be I'm aiming for about -1 degree Quote Link to comment Share on other sites More sharing options...
Tony Posted March 12, 2013 Report Share Posted March 12, 2013 How did it go? Quote Link to comment Share on other sites More sharing options...
liner33 Posted March 12, 2013 Author Report Share Posted March 12, 2013 This weekend , couldnt do it last weekend due to mothers day Quote Link to comment Share on other sites More sharing options...
Tony Posted March 12, 2013 Report Share Posted March 12, 2013 You should have got mum to give you a hand Quote Link to comment Share on other sites More sharing options...
liner33 Posted April 7, 2013 Author Report Share Posted April 7, 2013 Right only got around to this yesterday What a pain in the **** , took me over two hours to do one side , not really a one man job and has had a limited impact , camber is about 1.5 each side now though but i'm going to have a rethink Interestingly the vibration from the wheel has lessened Quote Link to comment Share on other sites More sharing options...
Tony Posted April 8, 2013 Report Share Posted April 8, 2013 How did you get on adjusting them? Quote Link to comment Share on other sites More sharing options...
liner33 Posted April 8, 2013 Author Report Share Posted April 8, 2013 I just put them in at the maximum point ie , with the offset hole away from the car to kick the strut out It looks like the will turn ok the longer bolt with the nut bottoms out so will spin the whole centre so you just lock it in place with the nut Quote Link to comment Share on other sites More sharing options...
Tony Posted April 8, 2013 Report Share Posted April 8, 2013 As said i've never managed to move the adjusters Quote Link to comment Share on other sites More sharing options...
