liner33 Posted December 9, 2012 Report Share Posted December 9, 2012 Here is the sheet from the last alignment , note the rear camber is out due to the car being lowered , I will need to fit aftermarket arms like these, or bushes to give the required adjustment , but whats likely to be up with the front right?? Quote Link to comment Share on other sites More sharing options...
Tony Posted December 10, 2012 Report Share Posted December 10, 2012 According to the OSF SAI reading the lower arm/ wishbone has a bend on it. Quote Link to comment Share on other sites More sharing options...
liner33 Posted December 10, 2012 Author Report Share Posted December 10, 2012 ok mate thanks for that looks like i need to go shopping for a new lower arm Quote Link to comment Share on other sites More sharing options...
Tony Posted December 10, 2012 Report Share Posted December 10, 2012 That or an adjustable upper A arm. Quote Link to comment Share on other sites More sharing options...
liner33 Posted December 10, 2012 Author Report Share Posted December 10, 2012 I guess it depends on how bent it is , I wouldn't be happy knowing it was bent even if it was correctly adjusted Quote Link to comment Share on other sites More sharing options...
Tony Posted December 10, 2012 Report Share Posted December 10, 2012 It's very common that the lower arm gets a slight bend, within reason it's nothing to worry about. Quote Link to comment Share on other sites More sharing options...
