parthiban Posted May 10, 2012 Report Share Posted May 10, 2012 I just bought a digital compact and was thinking I'll stick the SD I currently use in the D90 in this and get a new high speed one (as they're now a lot cheaper) for the Nikon. However I'm entirely confused about how the speeds work. As the D90 is quite old now I imagine there's no point in the superfast 95MB/s cards as it probably can't use it? Also I've always used Sandisk and the 16GB card I currently have works fine, yet for the D90 Nikon only approve Panasonic and Toshiba for sizes above 8GB. So should I get a Panasonic one or stick with Sandisk that I know well? Will probably end up buying one of the below: Sandisk Panasonic Quote Link to comment Share on other sites More sharing options...
Rich Posted May 10, 2012 Report Share Posted May 10, 2012 There probably isn't any need for a 95MB/s card and I doubt the D90 would be able use the top speed. A class 10 card like you have linked to would be perfect. Don't forget it's not always a good idea to go with 1 large card. If that fails you loose everything that's on it so getting 2 or 3 8GB cards would be better so if 1 failed you still have the photos on the other 2. Quote Link to comment Share on other sites More sharing options...
parthiban Posted May 10, 2012 Author Report Share Posted May 10, 2012 There probably isn't any need for a 95MB/s card and I doubt the D90 would be able use the top speed. A class 10 card like you have linked to would be perfect. Don't forget it's not always a good idea to go with 1 large card. If that fails you loose everything that's on it so getting 2 or 3 8GB cards would be better so if 1 failed you still have the photos on the other 2. I don't really ever leave much on the card so I'm not too worried from that perspective, a large card is just convenient when on holiday but otherwise even the 16GB rarely gets filled. Only thought to get a 32 as it makes more sense price wise. Any idea on Sandisk vs Panasonic or does it not really matter? Quote Link to comment Share on other sites More sharing options...
Rich Posted May 10, 2012 Report Share Posted May 10, 2012 I would go Sandisk, can't go wrong with them Quote Link to comment Share on other sites More sharing options...
