RobPhoboS Posted December 6, 2011 Report Share Posted December 6, 2011 Hey guys, I thought I'd post this here if anyone is interested. My car is using BC Racing coilovers (BR series), rear camber bolts, whiteline antiroll bars, standard wheels on Toyo T1R's. The T1R's have a huge amount of tyre wall flex on 15" wheels, which is at times, a bit unsettling but I've increased the pressure from 29/33 to 32/36. However, I'm not entirely sure if that's made a difference or not. Here is the before/after print out: Many thanks again guys for doing the work, hopefully in the next few days I'll be able to gauge how it feels (motorway journey home from WIM). Quote Link to comment Share on other sites More sharing options...
Tony Posted December 6, 2011 Report Share Posted December 6, 2011 Thanks for the feedback Rob..... She fought us along the way mainly because Pete wanted to sort the SAI as well as the camber, so the SAI was set on the pinch bolts and the camber with the top mount adjusters. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted December 7, 2011 Author Report Share Posted December 7, 2011 Hi Tony, I know just as I was leaving we very briefly spoke about the springs on my suspension. I effectively said that for road use, even on it's softest settings F & R, that I still think it feels a bit too harsh, and would softer springs help resolve this. I think you said I needed to find out if it was bump or rebound ? If so, is there a way I can diagnose that ? I'm fairly sure these are the spring rates: Front Spring Rate : 5kg/mm (280lbs/in) Rear Spring Rate : 8kg/mm (448lbs/in) But I've noticed on their site they now offer (as well as 5/8kg): Front Spring Rate : 4kg/mm (224lbs/in) Rear Spring Rate : 6kg/mm (336lbs/in) Many thanks for any help on this ! p.s I've noticed that the car feels a LOT more stable, less tramlining and it feels like it turns in quicker/sharper. Quote Link to comment Share on other sites More sharing options...
Tony Posted December 7, 2011 Report Share Posted December 7, 2011 Front Spring Rate : 4kg/mm (224lbs/in) Rear Spring Rate : 6kg/mm (336lbs/in) Is quite a change, my only concern is could they be to soft. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted December 7, 2011 Author Report Share Posted December 7, 2011 Front Spring Rate : 4kg/mm (224lbs/in)Rear Spring Rate : 6kg/mm (336lbs/in) Is quite a change, my only concern is could they be to soft. I've noticed they have a lot of choices, so I'm not limited to that specific set-up of springs: http://www.bc-racing.co.uk/springs/ But as mentioned, I'm not sure if it is the spring rate, although the damping setting is set to 30 (softest) all round. So in my tiny mind, it seems to make sense that its the springs but of course I haven't a clue ! In the new year I'm hoping to get a few outings on track but probably not that many (£££). Quote Link to comment Share on other sites More sharing options...
Tony Posted December 7, 2011 Report Share Posted December 7, 2011 GAZ run 250/ 350 fast road/ occ track, 400/ 500 track. I think a track day will make your mind up. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted December 7, 2011 Author Report Share Posted December 7, 2011 GAZ run 250/ 350 fast road/ occ track, 400/ 500 track. I think a track day will make your mind up. Ah thanks for the info. I also emailed BC Racing just before posting this message originally to see what they said as well. The support chap is just finding out some info for me but initial response is for the 4/6kg largely with road/occ track. I guess the good thing is, if I try out the softer springs then later do more track days, at least I'll have the harder springs to swap over to. Who knows, maybe some roads will get resurfaced as well ! Quote Link to comment Share on other sites More sharing options...
Tony Posted December 7, 2011 Report Share Posted December 7, 2011 You wish Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted December 7, 2011 Author Report Share Posted December 7, 2011 You wish Too right, forget world peace - just give us smooth asphalt please Quote Link to comment Share on other sites More sharing options...
