Ross Posted October 31, 2010 Report Share Posted October 31, 2010 Hi All, My first post here and I've come a'begging. I have a 1997 Mitsubishi Pajero Exceed Long Wheel Base with Camber issues. Its slightly positive on the drivers side and very visibly negative on the passenger side. Most garages wouldn't have the first clue how to go about the shimming process on the upper suspension arm to adjust the camber and I'm wondering if anybody can recommend a garage in either North Yorkshire, County Durham or Teesside (Darlington, Middlesbrough, Stockton-on-Tees) who have the correct equipment to do the job properly on the first attempt? Thanks in advance for any assistance. Ross Quote Link to comment Share on other sites More sharing options...
scorps Posted October 31, 2010 Report Share Posted October 31, 2010 Welcome to WIM.. heres the map for the centres that are approved by Tony himself i think these are the centers that do geo as well, if not someone will correct me. http://www.wheels-inmotion.co.uk/tyre-fitting-centres.php Quote Link to comment Share on other sites More sharing options...
hms Posted October 31, 2010 Report Share Posted October 31, 2010 If you do find a company that is close on the map, then I think the way to do it would be to book it through the WIM site. That way Tony takes responsibility for the alignment, and sorting any issues, should, in the unlikely event, any arise. Having said that, these companies are approved by WIM and work to WIM standards so you should be OK. h Quote Link to comment Share on other sites More sharing options...
Ross Posted October 31, 2010 Author Report Share Posted October 31, 2010 Thanks for the replies fellas, much appreciated. Quote Link to comment Share on other sites More sharing options...
Tony Posted November 1, 2010 Report Share Posted November 1, 2010 Even those on our map would struggle with the shims. The only one north up to the task is> http://www.nigellangsgarage.co.uk/profile.htm Quote Link to comment Share on other sites More sharing options...
Ross Posted November 6, 2010 Author Report Share Posted November 6, 2010 Even those on our map would struggle with the shims. The only one north up to the task is> http://www.nigellangsgarage.co.uk/profile.htm Tony, Thank you, I'll give them a call when I'm sure that the suspension and steering linkage is in "as new" condition. Ross Quote Link to comment Share on other sites More sharing options...
Tony Posted November 6, 2010 Report Share Posted November 6, 2010 Be sure to mention the link. Quote Link to comment Share on other sites More sharing options...
