A question from 200SXOC peep
CIH
Is it possible to get replacement eccentric rear camber bolts from aftermarket ? Or track down OEM part numbers to source from dealers ? Does WIM have prefered suppliers for alignment parts such as EZ cams etc ? Can't find any internet listings at all.
The Geo machine can be asked to find tools and kits so i often use that or surf here> http://www.demon-tweeks.co.uk/
Work's '600 is offline and I can only find listings for the full adjustment arm. None appear to include the eccentric bolt ?
I think the rear would be an arm because the EZ cam would be in an active bushings, although saying that the rear of the Focus can have an EZ cam?
