Tony Posted May 22, 2006 Report Share Posted May 22, 2006 an easy way to remove a nut from a spinning shaft (this will only work if there is enough thread and if the nut is not seized, otherwise you'll risk damaging the remaining thread) is to screw on 2 nuts, lock them together, loosen the offending nut, unlock the locked nuts, tada.......only works with a spanner on the lowermost nut though, obviously... Wise words..... i have never thought of that method... well done! Quote Link to comment Share on other sites More sharing options...
Bazza Posted May 22, 2006 Report Share Posted May 22, 2006 an easy way to remove a nut from a spinning shaft (this will only work if there is enough thread and if the nut is not seized, otherwise you'll risk damaging the remaining thread) is to screw on 2 nuts, lock them together, loosen the offending nut, unlock the locked nuts, tada.......only works with a spanner on the lowermost nut though, obviously... Wise words..... i have never thought of that method... well done! sounds ingenious shall give it a try.........when i get time Quote Link to comment Share on other sites More sharing options...
Janey Posted May 23, 2006 Author Report Share Posted May 23, 2006 Hehe...how to make more work for a stressed man.......... Order a set of lowering springs, so the whole lot have to come off Quote Link to comment Share on other sites More sharing options...
Tony Posted May 23, 2006 Report Share Posted May 23, 2006 Hehe...how to make more work for a stressed man.......... Order a set of lowering springs, so the whole lot have to come off I'm sitting here smiling at the thought of bazza having to remove/re-fit the suspension then i realised this means i have to set the bloody thing back up again....... woe......oh woe...... Quote Link to comment Share on other sites More sharing options...
Bazza Posted May 23, 2006 Report Share Posted May 23, 2006 bloody women my motto is fast becoming: leave what could be done today, because tomorrow she will have changed her mind Quote Link to comment Share on other sites More sharing options...
Tony Posted May 23, 2006 Report Share Posted May 23, 2006 bloody women my motto is fast becoming: leave what could be done today, because tomorrow she will have changed her mind No...No mate.... Don't let janey see this man talk or it will blow our cover... Excuses should be.... 1: Sorry luv i need a special tool for that job. (then buy your next man tool ) 2: Have the shop pump up the cost of her repair as part deposit for your own cars modifications 3: Explain that whilst mending her car you wont have time to furnish the gardening so she has to do it... then out of sight...... tinker with your own car instead 4: Make it obvious that you have spent.. hours and hours researching a resolution online in all manner of forums and suggested web sites, desperately seeking conclusive results regarding the issue.... (porn ) and you are now exhausted from this research requiring bed 5: Try again tomorrow Quote Link to comment Share on other sites More sharing options...
Janey Posted May 24, 2006 Author Report Share Posted May 24, 2006 No...No mate.... Don't let janey see this man talk or it will blow our cover... Excuses should be.... 1: Sorry luv i need a special tool for that job. (then buy your next man tool ) 2: Have the shop pump up the cost of her repair as part deposit for your own cars modifications 3: Explain that whilst mending her car you wont have time to furnish the gardening so she has to do it... then out of sight...... tinker with your own car instead 4: Make it obvious that you have spent.. hours and hours researching a resolution online in all manner of forums and suggested web sites, desperately seeking conclusive results regarding the issue.... (porn ) and you are now exhausted from this research requiring bed 5: Try again tomorrow Well I would do things myself, but I need guidance and a strong man to help and I'm not sure Barrie has full faith in my workwomanship for example : Last week I had a day off work.........I said to him that I had 2 choices, either go shopping or play with the car...............he said "Go shopping" Quote Link to comment Share on other sites More sharing options...
Tony Posted May 24, 2006 Report Share Posted May 24, 2006 Quote: janny Well did he do the car then? Or did it take a Sausage up the Trumpet to encourage any movement Quote Link to comment Share on other sites More sharing options...
