fluff34567 Posted May 8, 2019 Report Share Posted May 8, 2019 Hi all, My friend has a BMW 2007 525 diesel estate with the factory run flats. All 4 wheels are wearing on the inside, I remember an old post from Tony with a similar issue on a x5. Are there revised settings for the 525d to reduce the wear? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Tony Posted May 8, 2019 Report Share Posted May 8, 2019 Problem is BMW maintained the geometry positions for control at optimum speed. The issue is the RFT cannot deform and adopt the sport positions. Most times the main problem is the rear since this has the most negative camber. We simply use the camber tolerance and dial that out. Taking camber away will affect handling but only at the top end speed wise. Quote Link to comment Share on other sites More sharing options...
fluff34567 Posted May 9, 2019 Author Report Share Posted May 9, 2019 hi Tony, Many thanks for the response, if i understand correctly its a case of moving the rear camber to the max positive tolerance to reduce the inner wear or do you have some alternate settings available ? Quote Link to comment Share on other sites More sharing options...
Tony Posted May 9, 2019 Report Share Posted May 9, 2019 No just dial out the tolerance otherwise warning lights will come up on the dash. Quote Link to comment Share on other sites More sharing options...
