sootylfc Posted July 4, 2007 Report Share Posted July 4, 2007 Recently i had my front two tyres replaced mainly due to Inner tyre wear But before i had them replaced i had excessive shaking when slowing down and accelerating around 50mph I thougt the tyre change my solve this so had tyres replaced all wheels re - balanced and wheels realined This has reduced the shaking a bit but however it still happens, the car also pulls to the left too a bit. What things can i do. Was thinking of going to get brakes checked and while they was doing this as them to check the calipars? Anything else Would this have anything to do with the Geometry? i am thinking of taking it too this place http://www.4wheelalignment.co.uk/ what shall i do when attending any advice Quote Link to comment Share on other sites More sharing options...
Tony Posted July 4, 2007 Report Share Posted July 4, 2007 Hello and welcome to wim.... The Alignment you had done, was you given a printout?... Also what year is your car. Quote Link to comment Share on other sites More sharing options...
sootylfc Posted July 4, 2007 Author Report Share Posted July 4, 2007 Hello and welcome to wim.... The Alignment you had done, was you given a printout?... Also what year is your car. i got the wheel alignement done at tyrecare and they said the wheel alignement was fine and didnt need changing The Car is Lexus IS 200 W Reg 2000 Quote Link to comment Share on other sites More sharing options...
Tony Posted July 4, 2007 Report Share Posted July 4, 2007 Hello and welcome to wim.... The Alignment you had done, was you given a printout?... Also what year is your car. i got the wheel alignement done at tyrecare and they said the wheel alignement was fine and didnt need changing The Car is Lexus IS 200 W Reg 2000 Reads like is was basic laser alignment... You need a full Geometry and the wim positions (not Lexus) to stop the tyre wear and probably the pulling problem.... Do you have a destination in mind? Quote Link to comment Share on other sites More sharing options...
sootylfc Posted July 4, 2007 Author Report Share Posted July 4, 2007 Hello and welcome to wim.... The Alignment you had done, was you given a printout?... Also what year is your car. i got the wheel alignement done at tyrecare and they said the wheel alignement was fine and didnt need changing The Car is Lexus IS 200 W Reg 2000 Reads like is was basic laser alignment... You need a full Geometry and the wim positions (not Lexus) to stop the tyre wear and probably the pulling problem.... Do you have a destination in mind? yes i do tony the only one i could find in liverpool was http://www.4wheelalignment.co.uk/ Quote Link to comment Share on other sites More sharing options...
Tony Posted July 4, 2007 Report Share Posted July 4, 2007 Hello and welcome to wim.... The Alignment you had done, was you given a printout?... Also what year is your car. i got the wheel alignement done at tyrecare and they said the wheel alignement was fine and didnt need changing The Car is Lexus IS 200 W Reg 2000 Reads like is was basic laser alignment... You need a full Geometry and the wim positions (not Lexus) to stop the tyre wear and probably the pulling problem.... Do you have a destination in mind? yes i do tony the only one i could find in liverpool was http://www.4wheelalignment.co.uk/ This company> TDi-North 21 & 22 Aston Court, Kingsland Grange, Warrington, WA1 4SG Tel: 0800 0196055 Email: info@TDi-North.com Can correct the car to the wim positions without wim tutoring them. Are they near to you? Quote Link to comment Share on other sites More sharing options...
sootylfc Posted July 4, 2007 Author Report Share Posted July 4, 2007 Hello and welcome to wim.... The Alignment you had done, was you given a printout?... Also what year is your car. i got the wheel alignement done at tyrecare and they said the wheel alignement was fine and didnt need changing The Car is Lexus IS 200 W Reg 2000 Reads like is was basic laser alignment... You need a full Geometry and the wim positions (not Lexus) to stop the tyre wear and probably the pulling problem.... Do you have a destination in mind? yes i do tony the only one i could find in liverpool was http://www.4wheelalignment.co.uk/ This company> TDi-North 21 & 22 Aston Court, Kingsland Grange, Warrington, WA1 4SG Tel: 0800 0196055 Email: info@TDi-North.com Can correct the car to the wim positions without wim tutoring them. Are they near to you? yes warrington is only up the road really have you dealt with them before Quote Link to comment Share on other sites More sharing options...
Tony Posted July 4, 2007 Report Share Posted July 4, 2007 Hello and welcome to wim.... The Alignment you had done, was you given a printout?... Also what year is your car. i got the wheel alignement done at tyrecare and they said the wheel alignement was fine and didnt need changing The Car is Lexus IS 200 W Reg 2000 Reads like is was basic laser alignment... You need a full Geometry and the wim positions (not Lexus) to stop the tyre wear and probably the pulling problem.... Do you have a destination in mind? yes i do tony the only one i could find in liverpool was http://www.4wheelalignment.co.uk/ This company> TDi-North 21 & 22 Aston Court, Kingsland Grange, Warrington, WA1 4SG Tel: 0800 0196055 Email: info@TDi-North.com Can correct the car to the wim positions without wim tutoring them. Are they near to you? yes warrington is only up the road really have you dealt with them before Yes. They are part of the wim community and able to correct the chassis without intervention from wim..... A recommendation from me is a "fire and forget" situation since i have 100% confidence you will be dealt with in the wim-way. Quote Link to comment Share on other sites More sharing options...
sootylfc Posted July 4, 2007 Author Report Share Posted July 4, 2007 Hello and welcome to wim.... The Alignment you had done, was you given a printout?... Also what year is your car. i got the wheel alignement done at tyrecare and they said the wheel alignement was fine and didnt need changing The Car is Lexus IS 200 W Reg 2000 Reads like is was basic laser alignment... You need a full Geometry and the wim positions (not Lexus) to stop the tyre wear and probably the pulling problem.... Do you have a destination in mind? yes i do tony the only one i could find in liverpool was http://www.4wheelalignment.co.uk/ This company> TDi-North 21 & 22 Aston Court, Kingsland Grange, Warrington, WA1 4SG Tel: 0800 0196055 Email: info@TDi-North.com Can correct the car to the wim positions without wim tutoring them. Are they near to you? yes warrington is only up the road really have you dealt with them before Yes. They are part of the wim community and able to correct the chassis without intervention from wim..... A recommendation from me is a "fire and forget" situation since i have 100% confidence you will be dealt with in the wim-way. right then tony tomorrow i am going to phone them up and get it booked in ASAP will keep ya updated Andrew Quote Link to comment Share on other sites More sharing options...
Tony Posted July 4, 2007 Report Share Posted July 4, 2007 Hello and welcome to wim.... The Alignment you had done, was you given a printout?... Also what year is your car. i got the wheel alignement done at tyrecare and they said the wheel alignement was fine and didnt need changing The Car is Lexus IS 200 W Reg 2000 Reads like is was basic laser alignment... You need a full Geometry and the wim positions (not Lexus) to stop the tyre wear and probably the pulling problem.... Do you have a destination in mind? yes i do tony the only one i could find in liverpool was http://www.4wheelalignment.co.uk/ This company> TDi-North 21 & 22 Aston Court, Kingsland Grange, Warrington, WA1 4SG Tel: 0800 0196055 Email: info@TDi-North.com Can correct the car to the wim positions without wim tutoring them. Are they near to you? yes warrington is only up the road really have you dealt with them before Yes. They are part of the wim community and able to correct the chassis without intervention from wim..... A recommendation from me is a "fire and forget" situation since i have 100% confidence you will be dealt with in the wim-way. right then tony tomorrow i am going to phone them up and get it booked in ASAP will keep ya updated Andrew Your in good hands.. Mention the wim link. This will open a communication corridor between TDI north and wim. Although to date this has never been needed. Quote Link to comment Share on other sites More sharing options...
sootylfc Posted July 6, 2007 Author Report Share Posted July 6, 2007 Hello and welcome to wim.... The Alignment you had done, was you given a printout?... Also what year is your car. i got the wheel alignement done at tyrecare and they said the wheel alignement was fine and didnt need changing The Car is Lexus IS 200 W Reg 2000 Reads like is was basic laser alignment... You need a full Geometry and the wim positions (not Lexus) to stop the tyre wear and probably the pulling problem.... Do you have a destination in mind? yes i do tony the only one i could find in liverpool was http://www.4wheelalignment.co.uk/ This company> TDi-North 21 & 22 Aston Court, Kingsland Grange, Warrington, WA1 4SG Tel: 0800 0196055 Email: info@TDi-North.com Can correct the car to the wim positions without wim tutoring them. Are they near to you? yes warrington is only up the road really have you dealt with them before Yes. They are part of the wim community and able to correct the chassis without intervention from wim..... A recommendation from me is a "fire and forget" situation since i have 100% confidence you will be dealt with in the wim-way. right then tony tomorrow i am going to phone them up and get it booked in ASAP will keep ya updated Andrew Your in good hands.. Mention the wim link. This will open a communication corridor between TDI north and wim. Although to date this has never been needed. Car booked in for Tuesday Car is really bad at the min shaking pretty heavey Quote Link to comment Share on other sites More sharing options...
Tony Posted July 6, 2007 Report Share Posted July 6, 2007 This company> TDi-North 21 & 22 Aston Court, Kingsland Grange, Warrington, WA1 4SG Tel: 0800 0196055 Email: info@TDi-North.com Can correct the car to the wim positions without wim tutoring them. Are they near to you? yes warrington is only up the road really have you dealt with them before Yes. They are part of the wim community and able to correct the chassis without intervention from wim..... A recommendation from me is a "fire and forget" situation since i have 100% confidence you will be dealt with in the wim-way. right then tony tomorrow i am going to phone them up and get it booked in ASAP will keep ya updated Andrew Your in good hands.. Mention the wim link. This will open a communication corridor between TDI north and wim. Although to date this has never been needed. Car booked in for Tuesday Car is really bad at the min shaking pretty heavey I have spoken to Paul@ TDI north and they are 100% aware of you and your needs........ Enjoy Quote Link to comment Share on other sites More sharing options...
sootylfc Posted July 8, 2007 Author Report Share Posted July 8, 2007 I have spoken to Paul@ TDI north and they are 100% aware of you and your needs........ Enjoy thanks alot tony will let ya no how is goes Quote Link to comment Share on other sites More sharing options...
sootylfc Posted July 24, 2007 Author Report Share Posted July 24, 2007 i have given them 2 weeks to get back to me but they havnt i asked them for a print out they said they provide print outs so asked them to email me the results they said fine. After two reminders they still havnt done it So i can not tell you what they have done Quote Link to comment Share on other sites More sharing options...
Tony Posted July 24, 2007 Report Share Posted July 24, 2007 i have given them 2 weeks to get back to me but they havnt i asked them for a print out they said they provide print outs so asked them to email me the results they said fine. After two reminders they still havnt done it So i can not tell you what they have done This is very odd... Sorry sootylfc. Can you pm me your details name/ date when the Geometry was done and your registration number.... And i will personally see where the error has been. Quote Link to comment Share on other sites More sharing options...
sootylfc Posted July 24, 2007 Author Report Share Posted July 24, 2007 i have given them 2 weeks to get back to me but they havnt i asked them for a print out they said they provide print outs so asked them to email me the results they said fine. After two reminders they still havnt done it So i can not tell you what they have done This is very odd... Sorry sootylfc. Can you pm me your details name/ date when the Geometry was done and your registration number.... And i will personally see where the error has been. done Quote Link to comment Share on other sites More sharing options...
