Tony Posted July 17, 2007 Report Share Posted July 17, 2007 Inside rear "lift off" on a turn is common with a ridged chassis.. The seat belt replacement is interesting.... Since you weren't notified directly it's not a recall. More a replace silently when the car is available type of recall No, it was a recall. I was notified by my local stealership to take mine in to have the front belts replaced. It depended on your VIN as a batch of recoils apparently had incidences of hang ups where the belt wouldn't consistently reel out or in. Didn't have a problem with mine but they changed them anyway. The new ones have a slight striped pattern to the weave of the belt material which is hardly noticable unless you compare them to the original rear belts. We discussed it on LOC a while ago. I guess some were missed. Think it was technical bulletin BO010-05 OCT 05 Restraints - Seat Belt Extenders . Thank you for the complete story.... It's a little worrying any re-calls were missed with something so important as the seat belts. Hopefully your confirmation of the bulletin will help any owners that surf wim. Quote Link to comment Share on other sites More sharing options...
Tango Posted July 17, 2007 Report Share Posted July 17, 2007 I think they only recall if it's a safety or reliability issue, with most of the other TB's used if/when a customer has a complaint like the 'rattle' issue with the dash that seems to have effected most 220D's and even a few 250's. The seatbelt was definitely a safety issue so it should have been recalled if it was in the VIN group effected. I had a brand new set of mats in the IS200 replaced under a TB because there was a chance of the original design getting caught under the accelerator pedal. Again not a recall or a customer complaint but they changed them during a service. Depends on the dealer I guess...the cost is covered by Lexus GB so the dealer probably even makes a few £ on TB's. Quote Link to comment Share on other sites More sharing options...
