juzzyp Posted June 1, 2007 Report Share Posted June 1, 2007 Does Tony or any WIM member have any experience of S2000 geometry. I know the suspension setup is prone to seizing and I know Honda have released revised values for the S2000 for better handling, is their a recommended safe setup for this car as I know the rear-end can be a bit wayward on these cars if not setup correctly or earlier models. I've got a friend with an S2000 and he's a bit concerned as he's acquired one second hand. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 1, 2007 Report Share Posted June 1, 2007 Does Tony or any WIM member have any experience of S2000 geometry. I know the suspension setup is prone to seizing and I know Honda have released revised values for the S2000 for better handling, is their a recommended safe setup for this car as I know the rear-end can be a bit wayward on these cars if not setup correctly or earlier models. I've got a friend with an S2000 and he's a bit concerned as he's acquired one second hand. I have set quite a few. Mostly due to the owner losing the back end so often the measurements are for diagnostics or insurance repair validation. Several of these off's were due to the wrong compound tyres being fitted... Seemingly the S2000 is very sensitive to the shoes she wears. Quote Link to comment Share on other sites More sharing options...
