lspc Posted May 23, 2007 Report Share Posted May 23, 2007 Hi everyone ,just as above really heavy tyre wear on front inner edges of tyres approx 15mm taken to main dealers who said revised toe setting were ok could not advise what the problem might be apart from ive had Arden lowered springs fitted and 4 wheel alignment checked by a jaguar tuning specialist in ash vale hampshire.Many thanks for any advise .No kerb damage or accident damage as ive had since new vehicle seems to drive fine (i'm an ex mechanic of 17 years experience)i know jaguar have problems with tyre wear on several model s but cannot get any definitive answers cheers Lee. Quote Link to comment Share on other sites More sharing options...
Mark H. Posted May 23, 2007 Report Share Posted May 23, 2007 Welcome to wim . If you have a print out with the angles on that would probably help people work out what is a bit off if you were given a copy. Quote Link to comment Share on other sites More sharing options...
Tony Posted May 23, 2007 Report Share Posted May 23, 2007 Hello and welcome to wim. The patten you describe is camber. By lowering the car you also change the scrub radius, Probably negative. On your car the camber position i believe is adjustable? so easy to correct.... Do you have any past data on the measured positions? Quote Link to comment Share on other sites More sharing options...
