Heel & Toe wear
Here's a photo of bad heel and toe.
Down to the canvas on 4 areas of the tyre, approximately equally spaced around the periphery of the tyre. Believed it was caused by U/S shocks. Replacment with Abs Shocks GAZ cured the problem.
Wear was not easily visible due to the wear being on the inside, Lexie being low and me being an idle barsteward!
Tyres need a good check when you check your pressures weekly.
Luckily, issues noticed and changed before anything serious happened.
h
