seany260 Posted June 6, 2012 Report Share Posted June 6, 2012 hello people, I recently got hold of a B7 s4 and first thing i noticed is it was pulling to the left, so i went and got the wheel alignment done by a modern digital imaging (hawkeye) system. It was slightly out and did improve the pull but its still pulling slightly to the left. One other thing that it picked up was that the camber on the front right was sitting at 1degree 11minutes negative camber when it should only be 51minutes negative camber. But this is still within tolerance going by audi's settings. I was thinking that the little bit of extra camber on the right could push the car to the left, bit of a long shot thou. The more obvious thing that I was thinking would cause the pulling to the left is a weak bush in one of the arms at the left hand front wheel. note- its pulling to the left on good flat road, not just on roads that are slanted to the left. anyone with any ideas, fire away. thanx Quote Link to comment Share on other sites More sharing options...
Tony Posted June 6, 2012 Report Share Posted June 6, 2012 Is it a pysical pull or a change in direction when you straighten the steering wheel? Quote Link to comment Share on other sites More sharing options...
