Beachy Posted May 17, 2012 Report Share Posted May 17, 2012 Hello firstly being a new member I would like to say that I find the website and forum to be very informative and interesting. I have a totally standard 2001 MK4 VW Golf 1.6 SE 16V with 14" steel wheels. I had to get a pair of new front tyres for a recent MOT. I examined the old tyres (Firestone F580) and the n/s/f tyre was scrubbed below the legal limit on the inside 1/4 width of the tyre and the o/s/f was scrubbed below the legal limit on the outside 1/4 width of the tyre. There was about 3mm of tread remaining accross the rest of both tyres. If the tracking was out of adjustment I would have expected both front tyres to be scrubbed on the same side i.e. both outside or both inside. I understand that incorrect camber settings cause a narrow width of tyre wear. I have noticed that since having the new tyres fitted the steering wheel is slighly off centre to the right when driving in a straight line. Please could you advise what could be causing this? Many thanks Quote Link to comment Share on other sites More sharing options...
Tony Posted May 18, 2012 Report Share Posted May 18, 2012 Hello and welcome to wim The tyre wear can only be camber related since the Mk4 has an "optimised" camber adjustment. Most places won't have that data but if they follow the instructions then it's an easy fix. Quote Link to comment Share on other sites More sharing options...
Beachy Posted May 18, 2012 Author Report Share Posted May 18, 2012 Hello Tony, Wow, thanks for your prompt reply and the information complete with photos. If I am understanding this correctly the n/s/f has slightly too much negative camber and the o/s/f has slightly too much positive camber and this will also affect the tracking and steering wheel angle. I am guessing that it is only slightly out as the tyres lasted over 10,000 miles of gentle driving. I don't think my local tyre centre in Daventry has the equipment required to measure camber angle, just the front tracking. I see that you have a centre at Milton Keynes but I cannot find a way of booking a wheel alignment there online. Kind regards Mark Quote Link to comment Share on other sites More sharing options...
Tony Posted May 18, 2012 Report Share Posted May 18, 2012 Yes to negative and to positive, but fixable. You can book here online,all we need is a date and time, as for cost if we had to adjust everything including the rear, then worst case is £95+ vat. Quote Link to comment Share on other sites More sharing options...
Beachy Posted May 19, 2012 Author Report Share Posted May 19, 2012 Yes to negative and to positive, but fixable. You can book here online,all we need is a date and time, as for cost if we had to adjust everything including the rear, then worst case is £95+ vat. When I went to book a Wheel alignment / Steering geometry on the website it quoted me £45+vat. I selected Volkswagen Golf/Bora (1997 - 2006). Please can you explain what is causing the big difference in price. Thanks Mark Quote Link to comment Share on other sites More sharing options...
Tony Posted May 19, 2012 Report Share Posted May 19, 2012 Yes i can, it's thanks to a p**s poor web designer not giving me the keys to amend prices. The £45+ vat is for front toe only.. I am on the case. Quote Link to comment Share on other sites More sharing options...
Beachy Posted May 21, 2012 Author Report Share Posted May 21, 2012 Yes i can, it's thanks to a p**s poor web designer not giving me the keys to amend prices. The £45+ vat is for front toe only.. I am on the case. Thanks for the clarification. Quote Link to comment Share on other sites More sharing options...
mattgolf001 Posted August 6, 2012 Report Share Posted August 6, 2012 I have a similar problem with my golf mk4, after i replaced the steering rack. To do this i obviously had to remove the subframe and now have negative camber on driver side front and positive camber on the passenger side front, Do any of your branches do the subframe realignment? Quote Link to comment Share on other sites More sharing options...
Tony Posted August 7, 2012 Report Share Posted August 7, 2012 Milton Keynes and Chesham can without any problems, then only a few around the UK have the knowledge but you would need to suggest a centre to me before booking. Quote Link to comment Share on other sites More sharing options...
mattgolf001 Posted August 7, 2012 Report Share Posted August 7, 2012 Thanks for that Tony. I would prefer the chesham branch mate. What sort of cost would i be looking at. As cant book it until i know what its likely to cost so that i can make sure id have the cash Quote Link to comment Share on other sites More sharing options...
Tony Posted August 7, 2012 Report Share Posted August 7, 2012 I have replied to your email Quote Link to comment Share on other sites More sharing options...
mattgolf001 Posted August 7, 2012 Report Share Posted August 7, 2012 saw that thanks mate. Quote Link to comment Share on other sites More sharing options...
