chrisgixer Posted February 27, 2012 Report Share Posted February 27, 2012 Just picked one of these up for the Mrs. Very tidy, but every one I've seen seems to have varying degrees of inside edge wear on the fronts. Ours has reasonably new kumho ku31 with "ecsta" still visible on the centre tread, so fairly new, but looks like similar inside edge wear is starting already, even after set up at pro tyre .(sigh) Do factory settings work on these? Or do wim recommend other? Back feels a bit sloppy throwing into bends too. Bush issues? Quote Link to comment Share on other sites More sharing options...
Tony Posted February 27, 2012 Report Share Posted February 27, 2012 Factory settings won't work in regard to the front camber/ castor position. Setting the front camber to -10' will dramatically change the toe position, when this is corrected it will indirectly increase the castor angle. It's possible the castor position will violate UK spec, this is fine. Quote Link to comment Share on other sites More sharing options...
chrisgixer Posted February 27, 2012 Author Report Share Posted February 27, 2012 Ok Tony, I'll speak to her and get it booked in. Quote Link to comment Share on other sites More sharing options...
Tony Posted February 27, 2012 Report Share Posted February 27, 2012 Quote Link to comment Share on other sites More sharing options...
