Furutsun Posted December 16, 2011 Report Share Posted December 16, 2011 Hi all, I have a Ford Fiesta mk6. I have just noticed that my driver side rear wheel camber is a few degrees negative, this is causing slight wear on the inside of the tire. Now the mk6 has a solid rear axle with drum brakes. Therefore is there anything that can be done to adjust the wheel? I have found that they do shims to re-align the wheel hub, but I'm rather dubious of the idea. Can WIM do anything? Thanks for reading. Quote Link to comment Share on other sites More sharing options...
Tony Posted December 16, 2011 Report Share Posted December 16, 2011 It can be shimmed as can the caliper if it's on disc brakes, first thing though it to measure the chassis and find out exactly what's wrong. Quote Link to comment Share on other sites More sharing options...
