nick the greek Posted January 28, 2007 Report Share Posted January 28, 2007 Tony, on another forum I run, (I like to keep myself occupied!), one of my moderators has posted up his wheel alignment angles. http://www.stdrivers.co.uk/forum/showtopic.../last/m/1/#LAST FRONT WHEEL ALIGNMENT (at curb weight) Nominal Caster angle = 3.32deg (+/- 1.0deg) Nominal Camber angle = -0.88deg (+/- 1.25deg) Total toe = 0.20deg Toe-in (+/- 0.15deg) REAR WHEEL ALIGNMENT (at curb weight) Nominal Camber angle = -1.79deg (+/- 1.25deg) Total toe = 0.56deg Toe-in (+/- 0.15deg) NOTE: All angles given in decimal degrees. Just wondering if they are correct? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 28, 2007 Report Share Posted January 28, 2007 Tony, on another forum I run, (I like to keep myself occupied!), one of my moderators has posted up his wheel alignment angles. http://www.stdrivers.co.uk/forum/showtopic.../last/m/1/#LAST FRONT WHEEL ALIGNMENT (at curb weight) Nominal Caster angle = 3.32deg (+/- 1.0deg) Nominal Camber angle = -0.88deg (+/- 1.25deg) Total toe = 0.20deg Toe-in (+/- 0.15deg) REAR WHEEL ALIGNMENT (at curb weight) Nominal Camber angle = -1.79deg (+/- 1.25deg) Total toe = 0.56deg Toe-in (+/- 0.15deg) NOTE: All angles given in decimal degrees. ......................................................................... As i read things the positions are the destination not the actual positions...... Seemingly the desired "stock" positions are on display.... Quote Link to comment Share on other sites More sharing options...
nick the greek Posted January 28, 2007 Author Report Share Posted January 28, 2007 Yeah, I guess they must be the stock settings. Does it read sensible? (Or am I showing my ignorance ) Quote Link to comment Share on other sites More sharing options...
Tony Posted January 28, 2007 Report Share Posted January 28, 2007 Yeah, I guess they must be the stock settings. Does it read sensible? (Or am I showing my ignorance ) The figures displayed are the design positions. What is the thread holders complaint? ....... I read members are talking about having the "tracking" measured, i assume you will correct them on this error Nick!!!!!! Quote Link to comment Share on other sites More sharing options...
