Focus ST Alignment
nick the greek
Tony, on another forum I run, (I like to keep myself occupied!), one of my moderators has posted up his wheel alignment angles.
http://www.stdrivers.co.uk/forum/showtopic.../last/m/1/#LAST
FRONT WHEEL ALIGNMENT (at curb weight)
Nominal Caster angle = 3.32deg (+/- 1.0deg)
Nominal Camber angle = -0.88deg (+/- 1.25deg)
Total toe = 0.20deg Toe-in (+/- 0.15deg)
REAR WHEEL ALIGNMENT (at curb weight)
Nominal Camber angle = -1.79deg (+/- 1.25deg)
Total toe = 0.56deg Toe-in (+/- 0.15deg)
NOTE: All angles given in decimal degrees.
Just wondering if they are correct?
As i read things the positions are the destination not the actual positions...... Seemingly the desired "stock" positions are on display....
Yeah, I guess they must be the stock settings.
Does it read sensible? (Or am I showing my ignorance :) )
The figures displayed are the design positions. What is the thread holders complaint? ....... I read members are talking about having the "tracking" measured, i assume you will correct them on this error Nick!!!!!!
