johnny_52 Posted January 10, 2011 Report Share Posted January 10, 2011 Bout ye, I have a 07' Mk3 Mx5 Sport on 17"wheels. I have fitted Eibach 45mm lowering springs. The car is handling better but not as nice as i would like. I have booked it in with my local tyre fitter / mechanic. Have you got any figures or setup tips I could pass on? I would bring the car to WIM, but im in Belfast Any help would be appreciated Johnny Quote Link to comment Share on other sites More sharing options...
Tony Posted January 10, 2011 Report Share Posted January 10, 2011 Hello 45mm are you sure..... are they blue springs? Quote Link to comment Share on other sites More sharing options...
johnny_52 Posted January 10, 2011 Author Report Share Posted January 10, 2011 Hello45mm are you sure..... are they blue springs? The springs are red see: http://www.mx5parts.co.uk/product_info.php/products_id/1249 The car does sit quite low Johnny Quote Link to comment Share on other sites More sharing options...
Tony Posted January 10, 2011 Report Share Posted January 10, 2011 One more question...... soft or hard top? Quote Link to comment Share on other sites More sharing options...
johnny_52 Posted January 10, 2011 Author Report Share Posted January 10, 2011 One more question...... soft or hard top? Soft top Quote Link to comment Share on other sites More sharing options...
Tony Posted January 10, 2011 Report Share Posted January 10, 2011 i take it she's a daily drive?........ you not setting up for track or anything like that. Quote Link to comment Share on other sites More sharing options...
johnny_52 Posted January 10, 2011 Author Report Share Posted January 10, 2011 i take it she's a daily drive?........ you not setting up for track or anything like that. Yeah its my daily driver, however it will be doing 2-3 track days including the Ring, so maybe a setup inbetween if thats poss?? Johnny Quote Link to comment Share on other sites More sharing options...
Tony Posted January 10, 2011 Report Share Posted January 10, 2011 -45mm is very low for a mk3 so my only concern is the lower control arms are going to be perpendicular and this messes with the roll centres. In addition i have no idea what the coil rates are, i assume nothing to aggressive since they have to work with the Billie dampers. I would look for a calibration like this ( decimal degrees ) Rear Camber: -1 degree 50' Toe: +30' total Front Camber: -50' Castor: +6 degrees Toe: +8' total Be warned the front anti-roll bar drop links are going to brake, in this event we do rose jointed alloy links as a upgrade. Quote Link to comment Share on other sites More sharing options...
johnny_52 Posted January 10, 2011 Author Report Share Posted January 10, 2011 -45mm is very low for a mk3 so my only concern is the lower control arms are going to be perpendicular and this messes with the roll centres. In addition i have no idea what the coil rates are, i assume nothing to aggressive since they have to work with the Billie dampers. I would look for a calibration like this ( decimal degrees ) Rear Camber: -1 degree 50' Toe: +30' total Front Camber: -50' Castor: +6 degrees Toe: +8' total Be warned the front anti-roll bar drop links are going to brake, in this event we do rose jointed alloy links as a upgrade. Thanks very much, if i have any problems with the drop links ill be in touch pronto If im ever close by, ill pop in to let you guys have a look, thanks again Johnny Quote Link to comment Share on other sites More sharing options...
Tony Posted January 10, 2011 Report Share Posted January 10, 2011 Your welcome. Quote Link to comment Share on other sites More sharing options...
johnny_52 Posted January 15, 2011 Author Report Share Posted January 15, 2011 have had the geo done, it now seems to handle alot better I have noticed that it seems to bottom out at the back, at speed over bumps, any ideas how to fix? It seems i may need to invest in better shocks johnny Quote Link to comment Share on other sites More sharing options...
Tony Posted January 15, 2011 Report Share Posted January 15, 2011 -45mm is more than the recovery drop of 30mm..... welcome to the low club. Quote Link to comment Share on other sites More sharing options...
