e4tnu Posted July 30, 2010 Report Share Posted July 30, 2010 Ok here’s my pickle I have been looking for weeks now to try and buy a set of Eibach anti-roll bars for my 2009 mx5 r/c but everywhere I call says more or less the something that Eibach have had a problem with production and time estimates for delivery range from 8 weeks to April 2011. So my pickle is do I hold out for Eibach’s or is there an equal or better make out there? Quote Link to comment Share on other sites More sharing options...
Tony Posted July 30, 2010 Report Share Posted July 30, 2010 Have you tried Whiteline. Quote Link to comment Share on other sites More sharing options...
e4tnu Posted July 30, 2010 Author Report Share Posted July 30, 2010 I did look but for some reason I kept on getting the Australian site, but now I have got Balance motorsport they have some Whiteline bars on there so just sent an e-mail . Cheers Quote Link to comment Share on other sites More sharing options...
Tony Posted July 30, 2010 Report Share Posted July 30, 2010 Result Quote Link to comment Share on other sites More sharing options...
hms Posted July 30, 2010 Report Share Posted July 30, 2010 If that's what you want and everything is working OK now, then wait. Moss do something in their own brand Cobalt. Not sure how good it is. http://www.moss-europe.co.uk/Shop/ViewProd...teIndexID=10285 I have, I believe, Jackson Racing on my NA. Don't know if they do anything for the NC. Obviously you have tried MX5parts, have you tried ILM Germany, they provide some parts to MX5parts, maybe they have stock. (Although you should be able to get MX5 parts to order from them for you as they are ILM agents?) Sorry cannot be of more help! h Quote Link to comment Share on other sites More sharing options...
e4tnu Posted July 30, 2010 Author Report Share Posted July 30, 2010 Balance Motor sport only have H&R bars with a 2 week delivery but i do like the look of those Cobalt's bars. Quote Link to comment Share on other sites More sharing options...
hms Posted July 31, 2010 Report Share Posted July 31, 2010 Balance Motor sport only have H&R bars with a 2 week delivery but i do like the look of those Cobalt's bars. Cobalt don't state how much stiffer they are. They are also hollow pipe, so look like bits of bent gas pipe! (Being pipe does not make them bad, if they are designed correctly, just something in me says I want my ARB's out of solid!) Might be worth checking out on Miata.net see if there is any feedback on there. Search for Cobalt sway bars For starters: http://forum.miata.net/vb/showthread.php?t...obalt+sway+bars h Quote Link to comment Share on other sites More sharing options...
hms Posted July 31, 2010 Report Share Posted July 31, 2010 D'oh, it's not ILM but IL Motorsports. Some nice ARB's here: http://www.ilmotorsport.de/shop/article_de...9d2bf2d2ab3182f Euro 199 and TUV approved. h Quote Link to comment Share on other sites More sharing options...
e4tnu Posted July 31, 2010 Author Report Share Posted July 31, 2010 hms... Good call on the Cobalt one's they are indeed hollow I have just been on the Brian Goodwin site and he has recommended these. Racing Beat-designed NC Generation MX5 Miata sway bars reduce chassis roll in turns and increase your Miata's sensitivity to steering inputs, thereby improving maximum Miata cornering power. Substantial engineering effort, select steel alloys, and precise heat-treating processes combine in a superior product at a great price. The front Racing Beat MX5 Miata Sway Bar is a 1"OD tubular bar and features (3) adjustment setting holes, includes bushings, brackets and grease. The Rear Racing Beat MX5 Miata Sway Bar is a .75" OD tubular bar and features three adjustment setting holes, includes bushings, brackets and grease (not shown in picture)....everything you need to complete your installation! But just checked the Racing Beat site out and i think that these are hollow too ? Quote Link to comment Share on other sites More sharing options...
hms Posted July 31, 2010 Report Share Posted July 31, 2010 I don't think that hollow bar is important, just my personal preferrence. Goodwin has a good name in the States for Miata. What price are the racing beat? Doesn't show how stiff over OEM bars. h Quote Link to comment Share on other sites More sharing options...
e4tnu Posted July 31, 2010 Author Report Share Posted July 31, 2010 Specifications The Racing Beat Tubular MX-5 Front Anti Roll Bar, weighing only 7.5 lbs, is manufactured using1" OD (25mm) tubular steel, as compared to the .82" OD (21mm) Mazda stock sway bar. The Racing Beat Tubular MX-5 Front Sway Bar is designed with three (3) endlink mounting positions and is finished with a distinctive, red powder coating, providing a smooth, glossy protective layer. These Racing Beat sway bars are supplied with two powder-coated bushing retaining clamps, urethane bushings, Prothane bushing grease, and detailed installation instructions. These Racing Beat anti roll bars feature a pair of urethane Stopper Bushings, secured with band clamp retainers, serving as a preventative device against lateral movement of the sway bar during hard cornering. This simple and effective Stopper Bushing method effectively replicates the method used by Mazda on the stock bar. So i suppose that if they are bigger then they should be stiffer ? Quote Link to comment Share on other sites More sharing options...
hms Posted July 31, 2010 Report Share Posted July 31, 2010 I would assume they would be stiffer, otherwise they would not be much of an upgrade! I'm sure that a materials engineer would not assume thicker is stiffer, depends what material they are made of! h Quote Link to comment Share on other sites More sharing options...
Tony Posted August 1, 2010 Report Share Posted August 1, 2010 With three pick up points the bars have adjustable transverse loading, point to note the OEM drop-links are unlikely to cope with the extra load, but it just so happens we do uprated links for the 5 range Quote Link to comment Share on other sites More sharing options...
e4tnu Posted August 1, 2010 Author Report Share Posted August 1, 2010 Should have the bars in about a week and I will let you know so it can be booked in Quote Link to comment Share on other sites More sharing options...
hms Posted August 1, 2010 Report Share Posted August 1, 2010 What did you go for? h Quote Link to comment Share on other sites More sharing options...
e4tnu Posted August 2, 2010 Author Report Share Posted August 2, 2010 I went for the Racing Beat sway bars after some advice from Brian Goodwin. Apparently the standard bars on an N/C are hollow anyway and these ones are stiffer with 3 adjustment points on them. Link to site http://www.racingbeateurope.com/index.asp Quote Link to comment Share on other sites More sharing options...
