Tony Posted February 27, 2010 Report Share Posted February 27, 2010 Why Run Flat? Essentially, the idea behind Run Flat is to be able to keep driving with a partially or fully deflated tyre safely. The benefits of Run Flat are as follows: · Safety. The vehicle continues on a straight course, even after a sudden or slow puncture on one or several tyres, and remains in control. All dynamic safety systems such as the ABS, DSC, CBC etc. are still fully active. · Driving on. Even a moderately loaded vehicle with completely deflated tyres can be driven for at least another 150 km at a speed of 80 km/h. With a partial pressure loss, this distance increases to 1000 km, driving on residual pressure. (Remember that BMW did extensive co-development and testing with the six largest tyre manufacturers of Run Flat tyres before introducing Run Flat to its vehicles. These distances and speeds are failsafe, worst-case scenario figures. I personally completed more than 300 kms on a fully deflated tyre at an average speed of more than120 km/h. It doesn’t mean I am a hero, things like outside temperature, road condition and driving style will all impact on how far you can go before the tyre fails completely. To be safe, stick to the guidelines.) · Added safety and convenience. The damaged tyre no longer needs to be changed at the time and place where the failure happened- which might be on the highway, in a tunnel, in the rain or in a dangerous area. · More luggage space. The system eliminates the need to carry a spare wheel, car jack and tools. (This has caused much strife and confusion amongst 1 Series and 3 Series owners in particular, because their cars are not fitted with an emergency spare wheel. There is however now a solution to this for added peace of mind. From the parts department of your local BMW dealership, you can purchase a portable emergency spare wheel kit. The kit consists of an emergency spare wheel, a jack, a wheel spanner and a wedge to stop your car from rolling away. It all comes packaged in a neat carry-bag that can be neatly stored away when not in use. My only criticism is what on earth do you do with the flat wheel you have changed afterward? Still some work to do there. Ultimately, you really don’t need the spare, the Run Flats are good enough.) · Weight reduction. No emergency spare wheel means a saving of about 20 kg, which helps to reduce fuel consumption. · Integrated Run Flat indicator or TPM (Tyre Pressure Monitor). This enables early detection of slow punctures and thus helps prevent tyre damage. Sensors alert the drive if tyre pressure has dropped. More than 70% of all tyre damage is due to slow punctures. How does Run Flat work? A Run Flat system comprises three critical components. The Run Flat tyre, the Extended Hump (EH2) rim and the Run Flat indicator. Here is how each of them work in detail. · Run Flat tyre. The concept of the self supporting tyre has actually been around since the late ‘60’s, but without the two other components was completely useless. The major difference between a conventional tyre and Run Flat tyre is the sidewall. The sidewall of a Run Flat is thicker and thus strengthened. This means that with no pressure, the sidewalls are supporting the tyre, the rim and in turn the car instead of air pressure alone. · EH2 rim. EH2 stands for E-xtended H-ump 2-two humps. The Run Flat tyre is only for use with the EH2 rims due to the two humps on the inside of the rim that has the functionality of keeping the tyre on the rim in the situation of a flat tyre. (Logically, air pressure is what holds a tyre and the rim in place together. No air pressure, the tyre disbands and you have a roly-poly. With Run Flat, the tyre is almost attached to the rim, which is why it is 100% safe in a blow-out.) · Run Flat indicator. Also known as TPM. Not all drivers notice the deteriorating handling of their vehicle as it gets spongier as a result of a slow puncture. This defect is even more difficult to recognise in a Run Flat tyre because the sidewalls remain rigid. The warning system therefore becomes vitally important as it is the only reliable way of alerting the drive to such a failure. That said, it does not exempt the driver from his obligation of checking the inflation pressures on a regular basis. Every 14 days is recommended. The Run Flat indicator therefore monitors tyre pressure by consistently comparing wheel speed and revolutions with the help of the signal from the ABS system. A significant loss of tyre pressure changes the circumference of the tyre and accordingly, the running speed of the tyre on the road. The driver is informed by both a warning light and an acoustic signal. Designed to warn the driver of an excessive loss of pressure, the system provides a warning as of a road speed of 15 km/h and with a loss in pressure of more than +- 30% from the last set value. Run Flat FAQ (Frequently asked questions) Q – History of Run Flat at BMW? A – The first vehicle to have Run Flat tyres fitted in the BMW Group was the Z8 and MINI with great success, then Z4 E85/86, 5 Series E60, 6 Series E63/64, 1 Series E87/81/82/88, 3 Series E90/91/92/93, X5 E70 and X6 E71. Q – What BMW vehicles do not have Run Flat tyres yet? A – Currently the following vehicles do not have Run Flat yet: X3, 7 Series and M products. Q – Why has BMW developed this system? A – Every driver’s nightmare: a tyre suddenly blows at high speed on the motorway, the car slews and can be brought under control only with difficulty. A hair raising situation even for experienced drivers or in bumper to bumper traffic on a secondary road where there is hardly enough room to safely leave your car without risk, BMW have found a solution in a set of safety tyres including a Tyre Pressure Monitor (TPM) system. Run Flat tyres therefore provide vital safety benefits. Q – What is the availability of Run Flat tyres? A – BMW SA has a network of dealers across the country that not only will be able to supply you with the required tyres, but are also able to fit them to the required quality standards. Most tyres suppliers also supply Run Flat tyres. A further extension of our support for this technology is through BMW-On-Call. Q – How far can one travel with a punctured Run Flat tyre? A – The flexible rubber springs in the side walls of the tyres ensure the tyre largely retains its lateral support even in the event of sudden, total pressure loss and remains operable within certain limits (150 km partly laden at max. 80 km/h, 50 km fully laden and 250 km in a vehicle that is not heavily loaded). In the case of typical punctures with very slow pressure loss, the vehicle can still be driven for approx. 500 to 2000 km at max. 80 km/h as from the TPM warning. Q – Can I replace a Run Flat tyre with a standard tyre? A – Technically Yes, BMW however does not recommend this (with the exception of an emergency situation where a Run Flat tyre is not available. In this case the tyre must be replaced with a Run Flat tyre at the earliest opportunity). The reason for this is that no spare wheel will be fitted to vehicles with Run Flat, therefore there is the risk of a situation of getting a puncture and having no spare wheel and no run flat tyre to drive on. Note: 5 Series (E60) 530i, 530d, 545i and 550i are the only models to have Run Flat technology and an emergency spare wheel. Q – What is the price of Run Flat tyres compared to normal tyres? A – The Run Flat tyre is approximately 15% to 35% higher than a normal tyre. (Two reasons for this. Firstly, it is a more expensive technology. A plasma screen costs a little more than a normal TV, doesn’t it? Secondly, as more and more manufacturers join the Run Flat parade, the tyre manufacturers will produce and sell higher volumes at a lower cost.) Q – Will I get the same mileage out of the Run Flat as I do with a normal tyre? A – Yes. Q – How do you identify a Run Flat tyre? A – There is an RSC identifying mark on the outer side wall of the tyre. (Most tyres are marked RSC, but some tyres are also marked as RFT or, RunOnFlat.) Q – What does RSC stand for and how does it work? A – (R-un flat S-ystem C-omponent). Indicating that these tyres are merely one component in a more comprehensive safety system. Q – How do I initialize the system? A – Regardless of whether your car is equipped with TPM or the Tyre Pressure Control (TPC) system, reinitialisation must take place every time the tyre pressure is adjusted or when wheels/tyres are changed in order to record the current pressure required. This calibrating process must be performed when the tyres are cold, to prevent the values from being falsified by higher temperatures. Initialization starts when the Tyre Pressure Monitor/Control button is pressed until the indicator lamp in the instrument cluster lights up yellow. After a brief driving time, from a speed of 15 km/h, the system learns the new reference values and the yellow indicator lamp goes out. The indicator lamp lights up red if a pressure loss is identified by the system. The driver is alerted to a system failure by the indicator lamp in the instrument cluster lighting up yellow. (This is the method for some of the older BMWs. In the newer models such as the 1, 3, 5, X5 and X6 it is done either through the iDrive if equipped, or through the On-Board computer.) Q – Do other manufacturers use Run Flats? A – Recently, Audi and Mercedes have also begun to recognise the advantages of Run Flat tyres. Mercedes now offers them as an optional extra for every new model. Audi is about to follow BMW’s lead and will introduce run flat tyres as standard for its vehicles in the near future This will inevitably lead to these tyres becoming even more readily available from tyre retailers. Q -Is it true that Run Flat tyres are subject to more wear than conventional tyres? A – No. If both tyres are subject to the same stresses, they will both experience equal wear. Vehicle durability tests performed on identical test tracks have confirmed this time and time again during the design and development process, using different BMW Group vehicles. However, Run Flat tyres respond a little more sensitively to changes in tyre pressure – to develop correct user behaviour, it is necessary to understand the function of the Run Flat indicator or TPM (Tyre Pressure Monitor). This does not replace regular pressure checks. In addition, the new models are consistently more powerful than the old ones. While this enables more dynamic driving, it also exposes the tyres to increased stresses and thus may reduce their service life a little. Q – Is it true that the ride comfort achieved with Run Flat tyres is inferior to that of conventional tyres? A – The ongoing design optimisation of Run Flat tyres and the adjustment of chassis and suspension systems have eliminated the initial drawbacks of Run Flat technology in terms of ride comfort. The new BMW Group vehicles have exactly the desired balance between handling ability and ride comfort. Q – Why do Run Flat tyres have flattened shoulders? A – For optimum handling, high-performance (HP) tyres have a smaller tread depth in the shoulder area than in the wider longitudinal grooves that contain the wear indicators. So what looks like wear on the outside shoulder of the tyre is in fact not tread wear at all. Q – At the end of the day, a spare wheel gives you an added feeling of safety – doesn’t it? A – The spare wheel has not been dropped – it has been replaced with a better and safer solution. With Run Flat technology, what you effectively have is four spare wheels. The emergency capabilities of Run Flat tyres listed in the user manual and in advertisements all relate to completely deflated tyres (0 bar): in this condition, which in practice is very rarely encountered, Run Flat tyres are designed to still last a considerable distance. Driving carefully (max. 80 km/h), with four persons on board, this distance averages around 150 km, or 50 km with maximum axle load or 250 km with a light load. This “Run Flat distance†represents the built-in reserve of the Run Flat tyre. Q – Can I use conventional tyres on a BMW that was designed to have Run Flat tyres? A – For all new vehicles which have been specifically designed with the Run Flat technology in mind, as well as all future vehicles of this type, conventional tyres can theoretically be used, but their use would not make sense. The engineering parameters and specifications of Run Flat tyres and conventional tyres are quite different, due to their different design concept; providing equally optimised conditions for both types of tyres would require a different vehicle and suspension design. Q – What is the difference between the Run Flat TPM (Tyre Pressure Monitor) and TPC (Tyre Pressure Control)? A – The Run Flat indicator indicates tyre failures, while TPC checks the tyre pressure. TPC monitors tyre pressure on an ongoing basis, based on direct measurements. The Run Flat indicator does not measure tyre pressure directly; it detects differences in the wheels’ rotational speed and thus can only indicate major pressure changes in one tyre compared to the others. This is sufficient to effectively address the most frequent causes of pressure loss encountered in driving, and the resulting tyre failures. The most common situation is a drop in pressure in one tyre. And the Run Flat indicator is enough to indicate to the driver that one of the Run Flat tyres is losing pressure. Q – How should I deal with complaints about “abnormal tyre wearâ€? A – When customers complain of “abnormal wear†and it is suspected that this may be due to a lack of pressure maintenance (manual pressure checks), the control units for the Run Flat indicator and TPC should be checked for the mileage count when the most recent initialisation took place. Based on this mileage count, it is usually possible to guess when the most recent initialisation and pressure check were performed. If this was a long time ago, then it may be assumed that tyre pressure was not checked and maintained on a regular basis. Q – Should front and rear wheels be swapped on a regular basis? A – Swapping tyres from front to back is not recommended for BMW vehicles, since it would impair dynamic performance. Tyres used for longer periods on cambered rear wheels are particularly likely to cause an unpleasant ride when mounted on the front wheels. In addition, such an instruction would run counter to the trend for longer and longer customer service intervals. Q – Is it possible to repair a damaged Run Flat tyre? A – BMW does not recommend tyre repairs. Tyres are a major safety component and should never be used in a “weakened†condition. This is particularly important for high-performance tyres, be they of conventional or Run Flat design. Note that we are not saying that you “cannot†but rather that we don’t “recommendâ€. Even if you refer back to a BMW owner’s manual from 1982 (long before Run Flat) you will find that “BMW do not recommend the repairing of tyresâ€. The procedure for repairing a Run Flat tyre is however the same as that for repairing conventional tyres, i.e. any standard puncture (in the tread area) can be repaired by an authorised specialist vulcaniser. The vulcaniser together with the customer however assumes responsibility for the work carried out. BMW cannot assume product liability for repaired tyres. This would have been the case with a conventional tyre as well. BMW however recommends that a tyre should only be repaired in an emergency, subject to the above. The repaired tyre should then be replaced at the earliest opportunity. A Run Flat tyre may also not be repaired if the vehicle has been driven in “Run Flat mode†(in other words, with 0 tyre pressure). Note that this is again exactly the same as what would have been the case with conventional tyres. We hope that this clears it all up for you. It should also be mentioned at this point that if at anytime you have a question about Run Flat tyres, or you experience any problems, BMW On Call are there to help and are fully equipped to do so. Just in case you don’t have it, their number is 0800 600 777, and the BMW Customer Service number is 0800 600 555. If you are still in doubt, speak to the Aftersales department of your local dealer. Quote Link to comment Share on other sites More sharing options...
HighlandPete Posted February 27, 2010 Report Share Posted February 27, 2010 It is a shame that a lot of what is written above, as good as it sounds, doesn't exactly work in the real world. I'm a BMW user of many years and the run-flat experience has almost cost BMW a loyal customer. The only way I've continued with my BMW is by removing the run-flats and driving on non run-flat tyres. Now I have a BMW that drives as I expect it to. The other option was to trade the car and move to another marque. I still believe the run-flats should be an option, there should still be the capability to have a spare wheel in the wheel well, for both run-flat and non run-flat fitment. HighlandPete Quote Link to comment Share on other sites More sharing options...
Tony Posted February 27, 2010 Author Report Share Posted February 27, 2010 I'm absolutely with you but i needed BMW to offer their opinion of the tyre and Q&A so there's a impartial understanding however argumentative. Quote Link to comment Share on other sites More sharing options...
