ChrisWhyte Posted March 3, 2009 Report Share Posted March 3, 2009 Hello I have a MKII mondeo that is pulling to the left and the nearside front is all worn on the outer edge - usual stuff! I've taken it to a big garage chain twice and its still no use so I need to get this problem sorted out somewhere else, where is recommended in the Glasgow area? I think it was just tracking that was done and I gather this is no good having a look round this here website.... Thanks! Quote Link to comment Share on other sites More sharing options...
Tony Posted March 3, 2009 Report Share Posted March 3, 2009 It's possible the pull is due the way the tyres worn, have you tried moving the fronts side-to-side just to test this? failing that if you type your postcode into this site> http://www.alignmycar.co.uk/ it will find the nearest Hunter machine to your addy.... what you are looking for is the castor to be measured. Quote Link to comment Share on other sites More sharing options...
ChrisWhyte Posted March 4, 2009 Author Report Share Posted March 4, 2009 It's possible the pull is due the way the tyres worn, have you tried moving the fronts side-to-side just to test this? failing that if you type your postcode into this site> http://www.alignmycar.co.uk/ it will find the nearest Hunter machine to your addy.... what you are looking for is the castor to be measured. I don't think its down to how the tyre has worn as they have only been on the front for around 8 months (about 4000 miles) and it has behaved this way since way before xmas anyway. I will take to my nearest place (McConechy's outlet it looks like) and probably get them to give me a tyre too. Cheers. Quote Link to comment Share on other sites More sharing options...
Tony Posted March 4, 2009 Report Share Posted March 4, 2009 It's possible the pull is due the way the tyres worn, have you tried moving the fronts side-to-side just to test this? failing that if you type your postcode into this site> http://www.alignmycar.co.uk/ it will find the nearest Hunter machine to your addy.... what you are looking for is the castor to be measured. I don't think its down to how the tyre has worn as they have only been on the front for around 8 months (about 4000 miles) and it has behaved this way since way before xmas anyway. I will take to my nearest place (McConechy's outlet it looks like) and probably get them to give me a tyre too. Cheers. Just be sure they measure the full Geometry not just the camber and toe. Quote Link to comment Share on other sites More sharing options...
