arizonasun Posted December 30, 2008 Report Share Posted December 30, 2008 Hi Tony You know me the guy who runs the mx5-3rdgenerationlimited.com website I dont know if you can answer this but I have been asked if this is ok or not to do this Can you lower the MX5 MK3 standard car (so it has standard suspension not the sports suspension with Bilstein shocks and also has 16" wheels not the 17" wheels) 35mm with the Mazda lowering kit and then put 17" wheels on it Will this effect anything as the MK3 only came with 17" wheels on the sport model with the sports suspension How would the car behave/ride lowered 35mm on standard suspension with 17" wheels You may not have even come across this before Any advice would be great Cheers mate Quote Link to comment Share on other sites More sharing options...
Tony Posted December 31, 2008 Report Share Posted December 31, 2008 Changing wheels has two main concerns.. 1: Offsets. Well this isn't an issue since both the nc's have the same hub/strut assembly. 2: Weight. The same should apply If you go for aftermarket rims then both of these points are a concern. In regards to the handling, it will vastly improve. Quote Link to comment Share on other sites More sharing options...
