Good news... EZ cams for bushings
Tony
Until today i didn't think they existed since the EZ cam has always been for static installation ie: strut.
Seemingly they are now available for dynamic bushings.... if this is the case then this opens many doors for many different types of adjustments.
The only difference is they have two washers with a tab that holds the main bolt central.
Is this the focus you "slammed" recently ?
Yep :crying_anim: .... Point to note about these kits if you come across them is that the instructions fail to mention you need to remove the captive bolts... their a real sod to get to with a grinder so i found heating the spot welds with a brassing nozzle made them easy to snap off.
Ah. I suppose it has to be as there's no tabs for the (external) cam lobes to push against ?
The hub since the toothed washers either side hold against the "whatever" stabilizer arm.
This is what an EZ cam looks like
