Tony Posted September 29, 2008 Report Share Posted September 29, 2008 Until today i didn't think they existed since the EZ cam has always been for static installation ie: strut. Seemingly they are now available for dynamic bushings.... if this is the case then this opens many doors for many different types of adjustments. The only difference is they have two washers with a tab that holds the main bolt central. Quote Link to comment Share on other sites More sharing options...
CIH Posted September 29, 2008 Report Share Posted September 29, 2008 Is this the focus you "slammed" recently ? Quote Link to comment Share on other sites More sharing options...
Tony Posted September 29, 2008 Author Report Share Posted September 29, 2008 Is this the focus you "slammed" recently ? Yep .... Point to note about these kits if you come across them is that the instructions fail to mention you need to remove the captive bolts... their a real sod to get to with a grinder so i found heating the spot welds with a brassing nozzle made them easy to snap off. Quote Link to comment Share on other sites More sharing options...
CIH Posted September 30, 2008 Report Share Posted September 30, 2008 Instructions read like an eccentric bolt kit but it doesn't look like one ? Quote Link to comment Share on other sites More sharing options...
Tony Posted October 1, 2008 Author Report Share Posted October 1, 2008 Instructions read like an eccentric bolt kit but it doesn't look like one ? The cam is internal..... a sort of off-set lobe on the bolt it's self Quote Link to comment Share on other sites More sharing options...
CIH Posted October 1, 2008 Report Share Posted October 1, 2008 Ah. I suppose it has to be as there's no tabs for the (external) cam lobes to push against ? Quote Link to comment Share on other sites More sharing options...
Tony Posted October 1, 2008 Author Report Share Posted October 1, 2008 Ah. I suppose it has to be as there's no tabs for the (external) cam lobes to push against ? The hub since the toothed washers either side hold against the "whatever" stabilizer arm. This is what an EZ cam looks like Quote Link to comment Share on other sites More sharing options...
