Gary_R Posted July 22, 2008 Report Share Posted July 22, 2008 Hey folks, only me again... I had my car aligned and two new tyres put on the rear over 5,000 milesa go. I have measured the tread accurately and noticed that the insides are showing slightly less wear than the outside - the previous set of tyres worn unevenly but were much worse. The outside tread channel is just under 7mm, the inside tread channel is just over 7mm - a small difference at the moment; is it worth trying to rectify the problem or is the difference so minimal its not worth it? This is only on the rears, the fronts are fine. Cheers Quote Link to comment Share on other sites More sharing options...
Tony Posted July 22, 2008 Report Share Posted July 22, 2008 I would say "yes"...... A little manipulation of the toe now will add miles. Quote Link to comment Share on other sites More sharing options...
Gary_R Posted July 25, 2008 Author Report Share Posted July 25, 2008 True - but a bit mift at the fact I've not long had an alignment check... Perhaps its time to find a different garage. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 25, 2008 Report Share Posted July 25, 2008 True - but a bit mift at the fact I've not long had an alignment check... Perhaps its time to find a different garage. Problem is most places won't look outside of the box as they perceive OEM positions as law.... There not, the OEM positions are suggestions. Quote Link to comment Share on other sites More sharing options...
