juzzyp Posted June 5, 2006 Report Share Posted June 5, 2006 This is not for the track but a general geometry aimed at street and track. Now these guys have considerable expertise when it comes to the MX5, they've spent 15 years developing parts for the car. What do you guys reckon to their recommended alignment settings: Front Caster: 5.0 degrees Camber: 1.0 degrees negative Toe: 1/16" total (1/32" per side) Rear Camber: 1.5 degrees negative Toe: 1/16" total (1/32" per side) Quote Link to comment Share on other sites More sharing options...
Janey Posted June 5, 2006 Report Share Posted June 5, 2006 This is not for the track but a general geometry aimed at street and track. Now these guys have considerable expertise when it comes to the MX5, they've spent 15 years developing parts for the car. What do you guys reckon to their recommended alignment settings: Front Caster: 5.0 degrees Camber: 1.0 degrees negative Toe: 1/16" total (1/32" per side) Rear Camber: 1.5 degrees negative Toe: 1/16" total (1/32" per side) Looks interesting Juzzy Should I try it out when I'm back at Tony's (post new springs) then we can have a full review Quote Link to comment Share on other sites More sharing options...
Tony Posted June 5, 2006 Report Share Posted June 5, 2006 This is not for the track but a general geometry aimed at street and track. Now these guys have considerable expertise when it comes to the MX5, they've spent 15 years developing parts for the car. What do you guys reckon to their recommended alignment settings: Front Caster: 5.0 degrees Camber: 1.0 degrees negative Toe: 1/16" total (1/32" per side) Rear Camber: 1.5 degrees negative Toe: 1/16" total (1/32" per side) I have set a few to these positions.... are they Lannys? The camber settings are conservative for tyre wear and the rear invites under-steer..... The extended Castor provides steering feed back and high speed security.... Toe Positive (total) at 1.75 to 3.4 mm adds to 'turn in' response... a nice over-all package. Quote Link to comment Share on other sites More sharing options...
jon Posted June 6, 2006 Report Share Posted June 6, 2006 Is that total camber or per side? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 6, 2006 Report Share Posted June 6, 2006 Is that total camber or per side? Per side.... Camber reference is singular... Toe being Linear can be read as 'total' Quote Link to comment Share on other sites More sharing options...
jon Posted June 6, 2006 Report Share Posted June 6, 2006 I was just trying to work out how 1.5degrees -ve camber is 'conservative for tyre wear'. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 6, 2006 Report Share Posted June 6, 2006 I was just trying to work out how 1.5degrees -ve camber is 'conservative for tyre wear'. On the MX5 the camber positions are 'trim height' dependant, a rear trim of between 346-355mm would realise a natural -1 deg 14' taken as 60'/1 deg...... the scale shown 100'/1 deg converts to 1deg 30' at 60'/1 deg so the extra 16' is conservative and result in little tyre wear. Quote Link to comment Share on other sites More sharing options...
juzzyp Posted September 1, 2006 Author Report Share Posted September 1, 2006 Interesting reading Tony, I know a few are interested in moving over to these settings. I having a look into these but Im very happy with mine at the moment. Quote Link to comment Share on other sites More sharing options...
Tony Posted September 1, 2006 Report Share Posted September 1, 2006 Interesting reading Tony, I know a few are interested in moving over to these settings. I having a look into these but Im very happy with mine at the moment. What would be interesting is an MX5OC set-up, by example? Then categorize them into domestic, fast road and race.. establish proven positions for the club and club members. wim has explored many positions for the members but other than the visible praise in the club nothing is published (Geometrically) Whist wim is within STS then we have an opportunity to explore set-ups. When wim is transported into the wim/tdi collaboration this privilege will be lost..... Reads odd Actually no? Exploration with set-ups would never normally be so open in any company, expertise comes with a price tag, that's business! I would like to ascertain the best for all parties and transport the results now into the catalogue format mentioned above. Quote Link to comment Share on other sites More sharing options...
