jammy Posted January 7, 2008 Report Share Posted January 7, 2008 as some ma have read,my primera eGT pump has gone.this would be a internal one from factory.im now lookin into a aftermarket one with a bit extra pressure.and also a external one rather the internal.as im able to suck petrol up with ease from tank with pump still in place.would the external one pull the fuel up still at it's rite rate?? or is there a conversion/blankin plate with feed pipe's etc aval to put in place of the OEM pump and then ad the external pump so realy im after some advice as to what to do and the bestest option of pump's aval,or do i go for an uprated direct replacment internal pump ie "skyline" or GTI-R pump's as told these will fit the mera tank's and wiring plug's ??? Quote Link to comment Share on other sites More sharing options...
