Tony Posted January 5, 2008 Report Share Posted January 5, 2008 Bumps steer is due to the radii of the steering arm and the wishbone being disproportionate.... As the suspension compresses the radii acts on the steering arm and momentarily steers the offending wheel. There are various solutions like re-positioning the steering rack or more commonly changing the perpendicular position of the track-rod-end through pin. The image below shows a lowered cars steering arms position as off horizontal and you can clearly see the rod-ends through pin very extended in a perpendicular position. Other than re-locating the steering rack a simple solution is this.... The steering arm into the blue adjuster allows toe correction, then if the arm is held the blue adjuster can allow correction of the through pin..... Simple Quote Link to comment Share on other sites More sharing options...
