Tony Posted May 14, 2006 Report Share Posted May 14, 2006 Vehicle 03 plate VW Transporter 97000 miles on the clock Position OSR The owner was totally unaware that the rear coil was broken, despite the fact that the vehicle is used to transport heavy loads What is unusual is the position of the brake. The helix being progressively wound normally brakes at the lower coil... The progressive deflection should be able to absorb the initial load taken at about 500lbn/nm accentuated. I have to assume this example is due to contamination during construction delivering a final visible flaw. Quote Link to comment Share on other sites More sharing options...
