Tony Posted October 20, 2007 Report Share Posted October 20, 2007 Either Super-trackers machine is doing the maths wrong or i'm missing the plot.... I have a Lexus IS200 with poor inner front tyre wear.... The cambers are the usual incorrect -30' or so but in this case the castors were very low so i tested the gains at a 10 degree (at the road wheel) lock left and right.... see reports left at 10 degrees Right at 10 degrees The cross camber/castor doesn't make sense, nor does the inner wheels toe left/right? Am i missing something or should i just contact Super-tracker and tell them their machine is pants for diagnostics? Quote Link to comment Share on other sites More sharing options...
Tony Posted October 25, 2007 Author Report Share Posted October 25, 2007 Ok seemingly i'm on my own with this one.... What i cannot understand is why the cross camber/castor moves from negative to positive since the inner wheels reference is "compiled data" from dead ahead? The machine must be wrong!! since there is no command to indicate the camber change or castor sweep how can it deduce a negative-positive disparity? Both inner cambers display positive left-right gain, both inner castors display castor loses left-right so the visible cross angles must be wrong Supertracker!!............ Your machine is pants for diagnostics Quote Link to comment Share on other sites More sharing options...
Sam@TDi Posted October 26, 2007 Report Share Posted October 26, 2007 Sorry Tony I hadn't seen this, I'd say your right in criticizing the data it doesn't look correct to me. I can't see anything too wrong with that set-up... maybe the customer regularly drives up lorry ruts? Quote Link to comment Share on other sites More sharing options...
Tony Posted October 26, 2007 Author Report Share Posted October 26, 2007 Sorry Tony I hadn't seen this, I'd say your right in criticizing the data it doesn't look correct to me. I can't see anything too wrong with that set-up... maybe the customer regularly drives up lorry ruts? Cheers Sam@TDi that's what i thought...... Maybe i'm asking more from machine than it's designed for I darent tell Supertracker...... I cost them enough when i figured out their last machine didn't add the maths correctly. Quote Link to comment Share on other sites More sharing options...
