Tony Posted September 28, 2020 Report Share Posted September 28, 2020 I'll try to make this post as understanding as i can. During the 80's and 90's the MB has pre-installed adjuster bolts. What we have here is an eccentric washer that when rotated pushes against the "horse shoe" compliance location. Into the 90's MB changed the method of adjustment that didn't have the pre-installed bolt? Now to adjust the front camber or castor there's a need to install adjuster bolts. Personally i think it's crap but at least we have a "method" to adjust the angles. So point one is the adjuster bolt Note the groves along the bolt. These will finish at 3 or 9 depending on the correction required. The adjuster bolts need to feed down the bushing rails Problem is the fitting is done blind Personally i think it sucks but MB say their cars a so well-built the car needs a small amount of correction. In around 2015 they changed the adjustment again which now involves replacing the actual bushing to form a adjustment. Depending on what direction need to adjust the bushing needs to be replaced with an off-set bushing?? Once again the range is very small meaning we normally need to replace a camber and caster bushing to generate the forces needed to dissolve the problem. For us a majority of MB's we need to calibrate are those that need adjuster bolts fitted.... Why change perfection when the pre-installed adjusters and their range worked perfectly? Quote Link to comment Share on other sites More sharing options...
