No not really, only because i don't have the buying power meaning I'll be to expensive. It's best to buy direct but be sure they are hub centric.
Share this post
Link to post
Is there any issue with spacers Geometry or additional wear wise?
Was thinking 30mm each side at the rear and 20mm each side at the front, what do you think?
When I know will buy the items and book in with you.
Thanks for your help and advice.
Andy
Share this post
Link to post
The rear isn't a problem but the front will need the camber re-directed so the contact patch is under the lower pivotal point ( ball joint )
Share this post
Link to post
Remember "hub centric" or you have endless vibration problems.
Share this post
Link to post
Got ir.
Already bought them, should be here next week.
Can you confirm price for fitting springs and spacers, including Geometry setup and if its a do it while you wait job.
If you dont want to discuss prices on the Forum, here is my email andy@1stmx.co.uk
Thanks
Share this post
Link to post
We charge £70ph + vat so it's wise to budget for two hours although we should get it done faster than that, problem free. I would also advise we fit some EZ cams so the front camber can be set. A pair of them cost £40+ fitted. The geometry would come to £70+ vat assuming the cambers are going to be set and fitting the spacers cost £0 since the wheels are off anyway.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
