Tony Posted November 15, 2018 Report Share Posted November 15, 2018 No not really, only because i don't have the buying power meaning I'll be to expensive. It's best to buy direct but be sure they are hub centric. Quote Link to comment Share on other sites More sharing options...
Andy Hutch Posted November 15, 2018 Author Report Share Posted November 15, 2018 Is there any issue with spacers Geometry or additional wear wise? Was thinking 30mm each side at the rear and 20mm each side at the front, what do you think? When I know will buy the items and book in with you. Thanks for your help and advice. Andy Quote Link to comment Share on other sites More sharing options...
Tony Posted November 15, 2018 Report Share Posted November 15, 2018 The rear isn't a problem but the front will need the camber re-directed so the contact patch is under the lower pivotal point ( ball joint ) Quote Link to comment Share on other sites More sharing options...
Andy Hutch Posted November 15, 2018 Author Report Share Posted November 15, 2018 OK I will get it all ordered and contact you to book in. Thanks again. Andy Quote Link to comment Share on other sites More sharing options...
Tony Posted November 16, 2018 Report Share Posted November 16, 2018 Remember "hub centric" or you have endless vibration problems. Quote Link to comment Share on other sites More sharing options...
Andy Hutch Posted November 16, 2018 Author Report Share Posted November 16, 2018 Got ir. Already bought them, should be here next week. Can you confirm price for fitting springs and spacers, including Geometry setup and if its a do it while you wait job. If you dont want to discuss prices on the Forum, here is my email andy@1stmx.co.uk Thanks Quote Link to comment Share on other sites More sharing options...
Tony Posted November 16, 2018 Report Share Posted November 16, 2018 Will this be the Abarth. Quote Link to comment Share on other sites More sharing options...
Andy Hutch Posted November 16, 2018 Author Report Share Posted November 16, 2018 Yes Quote Link to comment Share on other sites More sharing options...
Tony Posted November 16, 2018 Report Share Posted November 16, 2018 We charge £70ph + vat so it's wise to budget for two hours although we should get it done faster than that, problem free. I would also advise we fit some EZ cams so the front camber can be set. A pair of them cost £40+ fitted. The geometry would come to £70+ vat assuming the cambers are going to be set and fitting the spacers cost £0 since the wheels are off anyway. Quote Link to comment Share on other sites More sharing options...
Andy Hutch Posted November 16, 2018 Author Report Share Posted November 16, 2018 Thanks, will let you know when they are here and book in. Quote Link to comment Share on other sites More sharing options...
Andy Hutch Posted November 20, 2018 Author Report Share Posted November 20, 2018 Parts will be here tomorrow. Do you do Saturdays? Cheers Andy Quote Link to comment Share on other sites More sharing options...
Tony Posted November 20, 2018 Report Share Posted November 20, 2018 Sure do...... Which Sat and what time are you thinking? Quote Link to comment Share on other sites More sharing options...
Andy Hutch Posted November 20, 2018 Author Report Share Posted November 20, 2018 This next one, anytime you like? Quote Link to comment Share on other sites More sharing options...
Tony Posted November 20, 2018 Report Share Posted November 20, 2018 If it's this Sat coming I'll need to check the diary when i'm in next which will be Thursday. Quote Link to comment Share on other sites More sharing options...
Andy Hutch Posted November 21, 2018 Author Report Share Posted November 21, 2018 OK, let me know. Cheers Quote Link to comment Share on other sites More sharing options...
Tony Posted November 21, 2018 Report Share Posted November 21, 2018 As suspected this Sat is booked so it will be Sat 1st Dec, will that work for you? Quote Link to comment Share on other sites More sharing options...
Andy Hutch Posted November 21, 2018 Author Report Share Posted November 21, 2018 Yes, What time, 10-11am ish would be best for me? Thanks Quote Link to comment Share on other sites More sharing options...
Tony Posted November 21, 2018 Report Share Posted November 21, 2018 Excellent, I'll book tomorrow and confirm. Quote Link to comment Share on other sites More sharing options...
Andy Hutch Posted November 22, 2018 Author Report Share Posted November 22, 2018 Are we OK for the Saturday the 1st? Cheers Andy Quote Link to comment Share on other sites More sharing options...
Tony Posted November 22, 2018 Report Share Posted November 22, 2018 Only just got home..... Yep you turn up as near to 10.30 as you can and I've booked the geo ramp for 12.30pm Quote Link to comment Share on other sites More sharing options...
Andy Hutch Posted November 22, 2018 Author Report Share Posted November 22, 2018 Perfect. See you then. Thanks Andy Quote Link to comment Share on other sites More sharing options...
