redmazda Posted April 1, 2014 Report Share Posted April 1, 2014 Hi I have a mk3 mx5 1.8I with option pack soft top I have changed my standard 16"rims to the 17" 10sport sport rims and I've just ordered the Eibach lowering springs set from mx5 parts I think they say the drop is 30mm on the front and 25mm on the back so then I will get a GEO done so I'm after the correct settings for this set up thanks Quote Link to comment Share on other sites More sharing options...
Tony Posted April 2, 2014 Report Share Posted April 2, 2014 Hello Who will be calibrating the chassis? Quote Link to comment Share on other sites More sharing options...
redmazda Posted April 2, 2014 Author Report Share Posted April 2, 2014 Hi Tony a guy down here in s wales called Tom roach company nameBendini motorsport Quote Link to comment Share on other sites More sharing options...
Tony Posted April 2, 2014 Report Share Posted April 2, 2014 I see..... Well for that height the settings should be Rear Camber> -1 degree 42' Toe> +6' each side Front Camber> -51 Castor> + 6 degrees 34' Toe> +6' each side. Quote Link to comment Share on other sites More sharing options...
redmazda Posted April 2, 2014 Author Report Share Posted April 2, 2014 Thanks Tony for your help Quote Link to comment Share on other sites More sharing options...
Tony Posted April 3, 2014 Report Share Posted April 3, 2014 BE WARNED.... The MK3/ 3.5 has huge geometric tolerances of around +- 1 degree 30' for the key angles, please don't let them use them. The figures i displayed should be hit +- 5' at worst after the adjusters are tightened. Quote Link to comment Share on other sites More sharing options...
