gawinter_2000 Posted July 30, 2013 Report Share Posted July 30, 2013 Hi, I've just polybushed all of the wishbones (and removed many seized bolts). Next step is geometry alignment. As the car is lowered will the standard geometry settings still be applicable or do I need a custom setup? Do you have an set that I could pass on to the alignment place? The car is just a daily drive - no track use etc.. I was aiming on booking one of the places via your BlackBoots website as I'd rather not drive it as far as WIM whilst the geometry is out of whack. Thanks in advance Graeme. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 30, 2013 Report Share Posted July 30, 2013 Hello I would shoot for this..... Rear Camber -2 degrees Toe 0 Front Camber -1 degree Castor +6 degrees 45' Toe 0 Quote Link to comment Share on other sites More sharing options...
gawinter_2000 Posted July 30, 2013 Author Report Share Posted July 30, 2013 Thanks, Would it be the standard price (as published on blackboots for the S2000) for geometry or is it consider custom \ special? By the way I'm having difficulty booking a geometry only via the blackboots website. I keep getting an error message pop up at the end. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 30, 2013 Report Share Posted July 30, 2013 Sorry about that, the sites down at the moment. Quote Link to comment Share on other sites More sharing options...
