Vipercar93 Posted September 30, 2012 Report Share Posted September 30, 2012 I am trying to fit a 3ft length of LED lights into my boot along a metal support. I have cleaned it with alcohol and applied double sided tape, but the tape keeps coming undone. Any ideas? Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted September 30, 2012 Report Share Posted September 30, 2012 Can you wrap some tape round the metal support first, maybe masking tape? Then hopefully it will stick. Try a few inches first. Quote Link to comment Share on other sites More sharing options...
Vipercar93 Posted September 30, 2012 Author Report Share Posted September 30, 2012 It's part of the unibody, I cannot wrap anything around it. Quote Link to comment Share on other sites More sharing options...
phipck Posted September 30, 2012 Report Share Posted September 30, 2012 may need to consider a stronger type of double sided, there several strengths made by 3M which may need looking into Quote Link to comment Share on other sites More sharing options...
Vipercar93 Posted September 30, 2012 Author Report Share Posted September 30, 2012 Hmm will have to look into it more. Not all tapes are created equal =) Quote Link to comment Share on other sites More sharing options...
parthiban Posted October 1, 2012 Report Share Posted October 1, 2012 I am trying to fit a 3ft length of LED lights into my boot along a metal support. I have cleaned it with alcohol and applied double sided tape, but the tape keeps coming undone. Any ideas? Had exactly the same problem myself when I put LED strips in my boot, the double sided tape just won't stick properly. Swapped it for double sided foam tape from B&Q, been up there for several years now and still stuck strong Quote Link to comment Share on other sites More sharing options...
Vipercar93 Posted October 1, 2012 Author Report Share Posted October 1, 2012 Tried the foam tape too... didn't stick either. Going to go the 3m route and see if that stuff will stick. Quote Link to comment Share on other sites More sharing options...
parthiban Posted October 1, 2012 Report Share Posted October 1, 2012 "Hard as nails" tape is ridiculously strong too, might be overkill but should probably do the job. Quote Link to comment Share on other sites More sharing options...
