Rick101 Posted August 8, 2012 Report Share Posted August 8, 2012 Hi, Dropped into the depot at MK last week and had fantastic dervice from the guys there on my S-Type. They've had my recommendation. Had a work bush repaired and an wheel alignment setup. Though drive and braking is now straight I still feel quite unconfident on different surfaces. Depending where I am on the road, i'll still see the steering wheel swing to one side When driving over high white lines the car can feel totally unstable. A dead centre steering wheel still sees the car pull right. Tyres are Hankook and are about 60% worn The guys gave it a thorough check and said componets looks in good condition but can't help feeling the car should be more settled than it is. It is a fairly new purchase so it may just be an overactive imagination. Quote Link to comment Share on other sites More sharing options...
Tony Posted August 9, 2012 Report Share Posted August 9, 2012 Can you pm me the registration so i can check the report again. Quote Link to comment Share on other sites More sharing options...
Rick101 Posted August 10, 2012 Author Report Share Posted August 10, 2012 I think the alignment is correct Tony, on a flat piece of road with no steering input the car will drive relatively straight. It's the surface/cambers that seem to affect it, but it's more noticeable than any other car i've had. I've also found (only noticaeable at walking pace) applying the brakes causes a very slight pull left on the steering wheel. I've PM'ed the reg. As said above it may just be me being hypersensitive as it's a new purchase. Thanks. Quote Link to comment Share on other sites More sharing options...
Tony Posted August 10, 2012 Report Share Posted August 10, 2012 Got the pm, thanks.... I have pulled the geo report from the machine and everything is fine. I think the problem is the tyres. Quote Link to comment Share on other sites More sharing options...
Rick101 Posted August 10, 2012 Author Report Share Posted August 10, 2012 Could well be. Never had Hankook before, come the time i'll be in touch for advice. Thanks. Quote Link to comment Share on other sites More sharing options...
