Rick101 Posted July 23, 2012 Report Share Posted July 23, 2012 I'm aware of the problems with this model, worn bushes being the most common. I wonder if my sysmptoms indicate worn bushes or have I got something more serious amiss? Road camber has severe effect of vehicle direction. Hands off wheel whilst driving, steering weel will turn to 10:00 position. Hold wheel dead centre whilst driving car will pull slightly right. Heavy braking pulls car left towards NSF. I don't have a massive knowledge of geometry but understand the basics of toe, camber etc. Quote Link to comment Share on other sites More sharing options...
Rick101 Posted July 23, 2012 Author Report Share Posted July 23, 2012 Can't see how to edit a post but shoudl add, no unsual noises or knocking heard. Quote Link to comment Share on other sites More sharing options...
Rick101 Posted July 23, 2012 Author Report Share Posted July 23, 2012 Oh, and tyre wear seems (to my untrained eye) fairly even per tyre and across all four. Hankook tyres about 50% worn. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 23, 2012 Report Share Posted July 23, 2012 Hi Rick When did the problem begin? Normally on your type of the the criminal is the front wishbone compliance bushing A lever between the wishbone and the chassis will prove or deny this. Quote Link to comment Share on other sites More sharing options...
Rick101 Posted July 23, 2012 Author Report Share Posted July 23, 2012 Bought it 7 days ago! Last service with Jag was about 14 months ago, it's had a a service elsewhere since, but i'm not sure I trust it, much like the recent MOT as the horn even doesnt work! If it is the bushing that's worn, can you guys rectify it? Looking at a few Jag forums, it seems Jaguar replace the whole wishbone but it is perfectly possible just the replace the bush itself. Would I need to do both sides if only one side is worn? Rough cost per side? Thanks Quote Link to comment Share on other sites More sharing options...
Tony Posted July 23, 2012 Report Share Posted July 23, 2012 We can just replace the bushing. Cost is hourly rate of £70+ vat and it shouldn't take long to do. Best thing to do is let us check it out at £0 cost so we determine exactly what's wrong and go from there. Quote Link to comment Share on other sites More sharing options...
Rick101 Posted July 23, 2012 Author Report Share Posted July 23, 2012 Sounds good. Working long days at the moment but I'm on nights back end of next week. I'll book it in for then. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 23, 2012 Report Share Posted July 23, 2012 Thanks. Quote Link to comment Share on other sites More sharing options...
Rick101 Posted July 28, 2012 Author Report Share Posted July 28, 2012 Well nipped into my local garage this morning simply to get it up on the ramp and have a proper look underneath it. Overall it got a thumbs up, pretty tight underneath, no major wear found. They did say there was wear on the inner of all four tyres and recommended a Geometry. Still not been able to access the valve & check pressure on NSF. Suspect it's low. So unless WIM find something next week that needs repair, it may just require alignment work. Quote Link to comment Share on other sites More sharing options...
Tony Posted July 28, 2012 Report Share Posted July 28, 2012 We can sort the air for you next week..... Quote Link to comment Share on other sites More sharing options...
