jon Posted January 27, 2007 Report Share Posted January 27, 2007 Q: And can you play around quite a bit with the current suspension layout. Is it flexible enough in terms of geometry that you can accommodate a number of camber angles etc? AN: Camber angles, yes, that’s easy. In truth, the front suspension has so little travel that the movement kinematics – things like camber change – aren’t that important. The rear suspension is where you might see more development by teams that have been on Michelins and are now on Bridgestones. http://www.itv-f1.com/Feature.aspx?Type=Ge...53&PO=38353 Quote Link to comment Share on other sites More sharing options...
Tony Posted January 27, 2007 Report Share Posted January 27, 2007 Q: And can you play around quite a bit with the current suspension layout. Is it flexible enough in terms of geometry that you can accommodate a number of camber angles etc? AN: Camber angles, yes, that’s easy. In truth, the front suspension has so little travel that the movement kinematics – things like camber change – aren’t that important. The rear suspension is where you might see more development by teams that have been on Michelins and are now on Bridgestones. http://www.itv-f1.com/Feature.aspx?Type=Ge...53&PO=38353 I agree with those statements for the race car... Geometry is a modifier when the suspension Kinematics cannot deliver required characteristics.. More important considerations are.... 1: Chassis calibration 2: Aerodynamics 3: Dynamic indexing 4: Tyres 5: Geometry In no particular order. Quote Link to comment Share on other sites More sharing options...
