hms Posted January 12, 2008 Report Share Posted January 12, 2008 Tony, in your posts you mention the car's parallelograms and how alignment will affect them. Can you explain where the parallelograms are formed, between all 4 wheels, between upper and lower wishbones? Thanks h Quote Link to comment Share on other sites More sharing options...
Tony Posted January 12, 2008 Report Share Posted January 12, 2008 It the un-sprung and sprung area of the chassis then the sub-systems interactions in between Quote Link to comment Share on other sites More sharing options...
hms Posted January 12, 2008 Author Report Share Posted January 12, 2008 It the un-sprung and sprung area of the chassis then the sub-systems interactions in between So in effect, in a 5 it's drawn between the inboard/outboard mounting points of the wishbones? h Quote Link to comment Share on other sites More sharing options...
Tony Posted January 12, 2008 Report Share Posted January 12, 2008 It the un-sprung and sprung area of the chassis then the sub-systems interactions in between So in effect, in a 5 it's drawn between the inboard/outboard mounting points of the wishbones? h The sprung will be the upper wishbone, the un-sprung the lower and the interactions in between is the suspension and associated systems like ARB-multi-links etc. Quote Link to comment Share on other sites More sharing options...
