liner33 Posted June 4, 2020 Report Share Posted June 4, 2020 A popular mod on the M-Lites ie (M135/m140/m235 and m240) is fitting the lower arm and tension arm from the BMW M4 The lower arm increases the camber (Which is not adjustable) by about -1 degree and the tension rod increases the caster. Apparently this does help the steering feel a great deal as well as offering more grip when cornering, the caster changes help the car self centre better which has always been an issue I feel Question is am I going to see ridiculous tyre wear on the roads if I do this , any other potential pitfalls ? Here is my last geo print out and this is a typical one after these changes Quote Link to comment Share on other sites More sharing options...
