Tony Posted April 14, 2006 Report Share Posted April 14, 2006 Does anyone know if modifying the Geometry to the extreme is against the law? Typical visual angle would be Camber.... if plod saw this could he do you for it? If yes then what would the offence be..... Quote Link to comment Share on other sites More sharing options...
Jap Devil Posted April 14, 2006 Report Share Posted April 14, 2006 As far as I'm aware, the only way plod could book you is under the "Construction & Use" legislation whereby plod would need to be able to show that the excessive camber was dangerous. Quote Link to comment Share on other sites More sharing options...
Tony Posted April 14, 2006 Author Report Share Posted April 14, 2006 As far as I'm aware, the only way plod could book you is under the "Construction & Use" legislation whereby plod would need to be able to show that the excessive camber was dangerous. Interesting..... i never thought the Geo could violate the law until a post here earlier. I wonder if anyone has ever been booked for the offence, even more interesting is the Geo is not part of the MOT even if the angles do look extreme.... whereas in Germany front wheel alignment is part of the test. Quote Link to comment Share on other sites More sharing options...
jon Posted May 2, 2006 Report Share Posted May 2, 2006 I guess something silly like a large amount of +ve camber that moved the top of the tyre outside of the bodywork could get you pulled? I've quite large camber on the front and i'd be VERY surprised if i got pulled for it. Quote Link to comment Share on other sites More sharing options...
Mr Yau Posted June 13, 2006 Report Share Posted June 13, 2006 On another note, wonder if a Geometry set-up would be classified as a "mod" to the standard factory specification for insurance purposes... especially if done for extreme settings (drifting, track days etc...) Quote Link to comment Share on other sites More sharing options...
Tony Posted June 13, 2006 Author Report Share Posted June 13, 2006 On another note, wonder if a Geometry set-up would be classified as a "mod" to the standard factory specification for insurance purposes... especially if done for extreme settings (drifting, track days etc...) Now there's a thought! technically the Geom would support the modifications so technically it should be declared..... Nah what insurance company would understand this?..... would the policy be by degrees or decrees Quote Link to comment Share on other sites More sharing options...
