Tony Posted May 7, 2007 Report Share Posted May 7, 2007 This owner has had dire bump-steer issues and contacted wim. I asked him to replace the steering damper and have the Geometry measured, which he did but not without consequence.... Here is the latest email. ................................................. Hi Tony, well after 4 weeks I have finally driven the Lexus to Berlin! If you have a few hours the story unfolds thus............. With only getting back to the UK every other weekend it took some sorting. I booked it in for a geometry check but decided to have a play before hand and having marked the positions I adjusted them from one extreme to the other - made no difference, still bad bump steer. So I set it back and left it to the garage to set - I've attached the printout. The following weekend home I picked it up and no change - they suspect the steering rack is buggered. So I ordered a new one from a breaker - £105, not too bad. I had noticed there's a bolt hanging down off the passenger side on the track rod end of the tie arm and I guessed there should be a damper of some sort fitted. Now there happened to be a GS300 for sale in the local dealer so I nipped down and had a look underneath - sure enough there's a damper fitted running parallel to the rack. So I phoned a Lexus dealer to see if mine should have one, yes they said and a new one is £280. Bugger that, so I phoned the breaker again and made sure the rack came with the damper too. By this time I'm back in Berlin so get the rack delivered direct to the garage who fit it, but are having trouble getting the steering wheel to be straight when the wheels are straight! On my next trip home I take it for a test drive and it's no different - still bump steers. Back at the garage I get them to raise it up on their lift and once underneath you instantly spot that the rack isn't parallel to the crossmember - passenger side is low by about 20mm. But the wierd thing is that the brackets seem correct and have been correctly fitted! Also, the rack didn't have a damper because I'm now told 1996 models didn't have them fitted ??????????? who is telling the truth I don't know. Anyway, I took the car away and played with the bracket and by putting a 12mm nut as a spacer between the bracket and the mounting lug on the subframe the rack is level and hey - no bump steer. I took it back to the garage the next day and got the tracking corrected again - job done, and drove the 940 miles from cornwall to berlin yesterday! Must say though that it's not as stable at high speeds as I though - not a problem in the UK but out here on the unrestricted autobahns it wasn't as planted as I thought it would be - but we are talking 130mph!!! seemed OK upto 100-110 but seemed to suffer from instability when one wheel only hit a bump. Could be that this will all be cured when I eventualy get the correct mounting bracket - but finding the correct part is gonna be fun! Also, it suffered from a lot of tyre roar - is that normal - or can I put it down to the crap tyres fitted - BARUM on the front CONTINENTAL eco somethings on the rears. Other than that it drove over really nice - managed roughly 31mpg so quite happy. Anyway - I hope I haven't bored the pants off you too much - any advice regarding the correct bracketry would be welcome. Cheers Steve ........................................ Here is the Geometry report. Can you see any problems on the report. Quote Link to comment Share on other sites More sharing options...
yemgi Posted May 7, 2007 Report Share Posted May 7, 2007 the individual toes front and rear. Left is negative and right is positive ? Quote Link to comment Share on other sites More sharing options...
Tony Posted May 7, 2007 Author Report Share Posted May 7, 2007 the individual toes front and rear. Left is negative and right is positive ? Certainly so in the initial readings. Here are my immediate concerns with this calibration. 1: Where are the after measurements. 2: Why is the nsf toe 12mm out and the osf 12mm in 3: Why is there such a disparity in the toe-out-on-turns Quote Link to comment Share on other sites More sharing options...
Roger440 Posted May 7, 2007 Report Share Posted May 7, 2007 the individual toes front and rear. Left is negative and right is positive ? Certainly so in the initial readings. Here are my immediate concerns with this calibration. 1: Where are the after measurements. 2: Why is the nsf toe 12mm out and the osf 12mm in 3: Why is there such a disparity in the toe-out-on-turns 1. On the right hand side off the screen? 2, Cos some numpty didn't centre the rack when they fitted it? But centred the steering wheel during the alignment chack 3, See 2 Well thats my take on it. Interesting the stering coupling etc(ive no idea what it consists of) was unaffected by the racks incorrect location. Quote Link to comment Share on other sites More sharing options...
jon Posted May 8, 2007 Report Share Posted May 8, 2007 What Roger said. The after figures are hidden on the right. Quote Link to comment Share on other sites More sharing options...
Tony Posted May 8, 2007 Author Report Share Posted May 8, 2007 the individual toes front and rear. Left is negative and right is positive ? Certainly so in the initial readings. Here are my immediate concerns with this calibration. 1: Where are the after measurements. 2: Why is the nsf toe 12mm out and the osf 12mm in 3: Why is there such a disparity in the toe-out-on-turns 1. On the right hand side off the screen? 2, Cos some numpty didn't centre the rack when they fitted it? But centred the steering wheel during the alignment chack 3, See 2 Well thats my take on it. Interesting the stering coupling etc(ive no idea what it consists of) was unaffected by the racks incorrect location. Odd the image is so large... It's fine on my screen, maybe my resolution is wrong. The toe and toot positions are wrong due to the incorrect horizontal alignment of the steering arms. Rack behind the wheel. so a lower arm toe's in and higher toe's out. Although after adjustment the toot will still be incorrect. Also the radii of the steering arm and the wishbone would be incorrect, subjecting the car to bump-steer. Quote Link to comment Share on other sites More sharing options...
