BuyPirelli Posted November 30, 2012 Report Share Posted November 30, 2012 Using a hunter, does it make any difference if I have my car aligned with a 7.5" width wheel, only to put an 8" on shortly after? E..g. would I be wasting my money? I'm pretty sure you can align a car without the wheels on it, so I'm hoping the alloys make no difference! Thanks Quote Link to comment Share on other sites More sharing options...
Tony Posted November 30, 2012 Report Share Posted November 30, 2012 A massive change in off set would be an issue and wider tyres need more consideration regarding the toe position. Quote Link to comment Share on other sites More sharing options...
BuyPirelli Posted November 30, 2012 Author Report Share Posted November 30, 2012 Offset is the same, diametre is the same, tyre size is the same...just alloy rim width is different. So I'm guessing from the inside of the car the tyre is in the same position regardless of alloy size, however its the outside tyre wall that is not quite so far out? Quote Link to comment Share on other sites More sharing options...
Tony Posted November 30, 2012 Report Share Posted November 30, 2012 At this level there wouldn't be a problem. Quote Link to comment Share on other sites More sharing options...
