Tony Posted June 25, 2018 Report Share Posted June 25, 2018 Why the arrow? Quote Link to comment Share on other sites More sharing options...
eddie Posted June 25, 2018 Report Share Posted June 25, 2018 Direction of travel? Wheel is balanced to go round this particular way? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 25, 2018 Author Report Share Posted June 25, 2018 Nope not that....Keep going. Quote Link to comment Share on other sites More sharing options...
eddie Posted June 25, 2018 Report Share Posted June 25, 2018 its only black on the outside and needs to be put on that way? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 25, 2018 Author Report Share Posted June 25, 2018 Nope....Keep going? Quote Link to comment Share on other sites More sharing options...
eddie Posted June 25, 2018 Report Share Posted June 25, 2018 they have a special pattern so you have to put the drivers side/passengers side on properly so the pattern spins right? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 25, 2018 Author Report Share Posted June 25, 2018 You're very close.......The true reason still remains. Quote Link to comment Share on other sites More sharing options...
P4UL T Posted June 25, 2018 Report Share Posted June 25, 2018 The cut outs in the wheel face are angled and direct air to aid cooling? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 25, 2018 Author Report Share Posted June 25, 2018 You got it....So did eddie really since they are handed... Basically the wheels ram-vent the brakes...The first to do this if i'm correct was the rally Audi Quattro.. Quote Link to comment Share on other sites More sharing options...
eddie Posted June 25, 2018 Report Share Posted June 25, 2018 learned something new today! Quote Link to comment Share on other sites More sharing options...
Tony Posted June 26, 2018 Author Report Share Posted June 26, 2018 I'll tell you something odd though?.....F1 wheels don't vent the brakes Quote Link to comment Share on other sites More sharing options...
Viking Posted June 27, 2018 Report Share Posted June 27, 2018 On an F1 car, aerodynamics are more important. Diverting airflow laterally through the wheels is very inefficient when you're looking for absolute airflow efficiency, so the brakes are cooled via ducted airflow taken from just the right place to provide the correct characteristics for a given car. No need for cooling via the wheels. For this reason they always pop a blower onto the cooling ducts whenever a car comes back into the pits to stop the brakes from overheating. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 27, 2018 Author Report Share Posted June 27, 2018 I totally agree.... F1 caters for a known stable airflow via the ducting..In fact i would think ducting via the wheel could add drag? Quote Link to comment Share on other sites More sharing options...
Rich Posted June 27, 2018 Report Share Posted June 27, 2018 What a good idea. What car are they from? Quote Link to comment Share on other sites More sharing options...
Tony Posted June 28, 2018 Author Report Share Posted June 28, 2018 A track originated BMW....I should think it vents the brakes to stop brake fade. Quote Link to comment Share on other sites More sharing options...
Tango Posted June 29, 2018 Report Share Posted June 29, 2018 Same as the Lexus ISF, each wheel has its own corner due to staggered width and blade direction. You often see them incorrectly fitted with the thicker section of the blades trailing when they should be leading (with the wheel rotating clockwise, of course), Quote Link to comment Share on other sites More sharing options...
Tony Posted June 29, 2018 Author Report Share Posted June 29, 2018 Hasn't the ISF also got ducting off the grill to focus cooling.... Very few OEM cars today have handed wheels, only Lancia and Lambo come to mind. Quote Link to comment Share on other sites More sharing options...
Tango Posted June 29, 2018 Report Share Posted June 29, 2018 Hasn't the ISF also got ducting off the grill to focus cooling.... Very few OEM cars today have handed wheels, only Lancia and Lambo come to mind. Yes it has, also vents in the front wings to expel the air from the front ducts. Quote Link to comment Share on other sites More sharing options...
Tony Posted June 29, 2018 Author Report Share Posted June 29, 2018 Just as important as induction, the heat has to go somewhere. Quote Link to comment Share on other sites More sharing options...
