Tony Posted March 15, 2007 Report Share Posted March 15, 2007 The Mondeo has suffered with inner front tyre wear, in particular those running on 17" wheels. Eibach now make an adjuster kit: Part number 5.89675k this is suitable for all models 96 on. Quote Link to comment Share on other sites More sharing options...
jammy Posted March 15, 2007 Report Share Posted March 15, 2007 (edited) The Mondeo has suffered with inner front tyre wear, in particular those running on 17" wheels. Eibach now make an adjuster kit: Part number 5.89675k this is suitable for all models 96 on. 96 on oh?m8 of mine at work has 94 m v6 and runs 18s.has tyre were issues on the front too.i thought all mondeo parts were compatible to 1 another from start of mk1 to end of mk2.will i be goin to work tomoro to tell him thay dont do them after telling him thay do this part for his beloved mondeo forgot to ad that i have put late shocks and hubs on a mk1 and visa versa before so surly the adjusters would actually do the job on any mk1 mk2????????? i bet essex racer will be sraight on the blower to eibach for these little babys Edited March 15, 2007 by jammy Quote Link to comment Share on other sites More sharing options...
Rich Posted March 15, 2007 Report Share Posted March 15, 2007 i bet essex racer will be sraight on the blower to eibach for these little babys Depends how much they are though! Any idea of a price Tony? Too be honest I haven't suffered with any tyre wear on the car since I've had it which is surprising with the problems I've had suspension wise. I'm hoping to be getting the Eibach springs tomorrow so that will lower the car 30mm, might start seeing some slight wear then! Quote Link to comment Share on other sites More sharing options...
jammy Posted March 15, 2007 Report Share Posted March 15, 2007 i bet essex racer will be sraight on the blower to eibach for these little babys Depends how much they are though! Any idea of a price Tony? Too be honest I haven't suffered with any tyre wear on the car since I've had it which is surprising with the problems I've had suspension wise. I'm hoping to be getting the Eibach springs tomorrow so that will lower the car 30mm, might start seeing some slight wear then! hummm camber adjusters i can see another mondeo entering my world. oh yessssss Quote Link to comment Share on other sites More sharing options...
Tony Posted March 15, 2007 Author Report Share Posted March 15, 2007 £122 inc for a pair has been seen from Demon tweeks. Quote Link to comment Share on other sites More sharing options...
Mark H. Posted March 15, 2007 Report Share Posted March 15, 2007 For 2 bolts? Quote Link to comment Share on other sites More sharing options...
Tony Posted March 15, 2007 Author Report Share Posted March 15, 2007 For 2 bolts? No mate.. This is for a adjustable top strut pillow mount. If the Mondeo had two lower strut mounts then life would be very happy.. unfortunately the strut is housed in the hub by one rigid cast and a locking bolt. Quote Link to comment Share on other sites More sharing options...
Rich Posted March 15, 2007 Report Share Posted March 15, 2007 I think I've seen a pic of these somewhere, but that's abit steep! Still I'm only going 30mm so hopefully I'll be ok... Quote Link to comment Share on other sites More sharing options...
jammy Posted March 16, 2007 Report Share Posted March 16, 2007 £122 inc for a pair has been seen from Demon tweeks. sounds like a bargain to me.will these fit all mondeos Quote Link to comment Share on other sites More sharing options...
Tony Posted March 16, 2007 Author Report Share Posted March 16, 2007 £122 inc for a pair has been seen from Demon tweeks. sounds like a bargain to me.will these fit all mondeos Listed as Mondeo 97 on. Quote Link to comment Share on other sites More sharing options...
Rich Posted March 16, 2007 Report Share Posted March 16, 2007 Do you think I would need some of these on a 30mm drop? I'm assuming they're aimed at mondeos that have been lowered 40mm plus as the camber will be worse? The springs I'm getting are the ones Ford uses if you choose the sports suspension package and they're compatible with standard shocks. I was reading an old post of yours on MEG regarding wishbone wear and lowering the car. As I'm lowering mine 30mm do you think I wouldn't have to change them as often? I was under the impression that the lower a car is the more pressure you're putting on them so they wear quicker? Quote Link to comment Share on other sites More sharing options...
Tony Posted March 16, 2007 Author Report Share Posted March 16, 2007 Do you think I would need some of these on a 30mm drop? I'm assuming they're aimed at mondeos that have been lowered 40mm plus as the camber will be worse? The springs I'm getting are the ones Ford uses if you choose the sports suspension package and they're compatible with standard shocks. I was reading an old post of yours on MEG regarding wishbone wear and lowering the car. As I'm lowering mine 30mm do you think I wouldn't have to change them as often? I was under the impression that the lower a car is the more pressure you're putting on them so they wear quicker? You would need to recover the camber in my opinion. As for the wishbones... The attitude of the bushings will be more aggressive adding wear but the camber gain will be less, so it's a matter of opinion really. Quote Link to comment Share on other sites More sharing options...
Mark H. Posted March 16, 2007 Report Share Posted March 16, 2007 Thats better value then . Quote Link to comment Share on other sites More sharing options...
jammy Posted March 17, 2007 Report Share Posted March 17, 2007 £122 inc for a pair has been seen from Demon tweeks. went on Demon tweeks earlyer for the camber adjusters i couldnt find any listed. all i could find was caster kits? does camber/caster imply the same meaning/same purpos Quote Link to comment Share on other sites More sharing options...
Tony Posted March 17, 2007 Author Report Share Posted March 17, 2007 £122 inc for a pair has been seen from Demon tweeks. went on Demon tweeks earlyer for the camber adjusters i couldnt find any listed. all i could find was caster kits? does camber/caster imply the same meaning/same purpos I need to contact Eibach myself to capture the full picture but.. Most pillow mount adjusters are camber/castor compensators combined in one unit? Quote Link to comment Share on other sites More sharing options...
jammy Posted March 17, 2007 Report Share Posted March 17, 2007 I need to contact Eibach myself to capture the full picture but.. Most pillow mount adjusters are camber/castor compensators combined in one unit? ok sorted tony.mentioned these to m8 at work today and he wants me to order them so just wanted to be sure before i place the order Quote Link to comment Share on other sites More sharing options...
Tony Posted March 17, 2007 Author Report Share Posted March 17, 2007 I need to contact Eibach myself to capture the full picture but.. Most pillow mount adjusters are camber/castor compensators combined in one unit? ok sorted tony.mentioned these m8 at work today and he wants me to order them so just wanted to be sure before i place the order Let me speak to Eibach and get some prices.... I will post the board as soon as! Quote Link to comment Share on other sites More sharing options...
jammy Posted March 17, 2007 Report Share Posted March 17, 2007 top geeza :graduated: cheers tony Quote Link to comment Share on other sites More sharing options...
Rich Posted January 30, 2008 Report Share Posted January 30, 2008 Tony, I've been reading about these camber adjusters and found this link to installing them - Click Me I know it's for a contour but they use the same kit as the mondeo? Anway, this bit that I've quoted below has got me thinking. 9. To adjust strut for camber and caster change remove the top nut and cover. Rotate the cam plate by installing a 3/8" ratchet and extension in the square hole. All of the weight must be off of the wheel and the suspension must be hanging before rotating cam plate. If the weight needs to be off the wheels when you adjust the plate how can you get accurate readings when doing the geo? As you would have to remove the top cover/nut, make the adjustments, replace cover/nut and then lower the car back down. It gives the impression it would take a while to find the correct setting if you're lowering/rasing the car all the time to make the adjustments. I'm assuming the top cover/nut would need to be in place when measuring the car otherwise there will be movement in the strut? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 30, 2008 Author Report Share Posted January 30, 2008 About 30% of cars with adjustable camber have to be adjusted with the wheels off the ground. The machines have a program where we tell it we are going to raise the car, the program measures the change in the camber during the lift then when prompted removes the gains from the live data. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 30, 2008 Report Share Posted January 30, 2008 That's cool then, not so hard to do by the sound of it Quote Link to comment Share on other sites More sharing options...
Tony Posted January 30, 2008 Author Report Share Posted January 30, 2008 That's cool then, not so hard to do by the sound of it No the machine does the math... In fact for MEG i have dropped the calibration fee (tonight) since the cars don't deserve the same fee as the Jap multiple adjust series. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 30, 2008 Report Share Posted January 30, 2008 Excellent, that will please Jammy with the problems he's been having! So what is the fee now? Quote Link to comment Share on other sites More sharing options...
Tony Posted January 30, 2008 Author Report Share Posted January 30, 2008 Excellent, that will please Jammy with the problems he's been having! So what is the fee now? For MEG members the fee is £85+ vat For MEG Gold members the fee is £85 including vat. Remember other forums have different paid fees to wim so the discount value does not disrupt our Gold fees by comparison for Mondeo members....... I think Anyhoo jammy gets a very special price Quote Link to comment Share on other sites More sharing options...
Rich Posted January 31, 2008 Report Share Posted January 31, 2008 Sounds good...does that include a free cup of tea Quote Link to comment Share on other sites More sharing options...
