Rich Posted March 1, 2012 Report Share Posted March 1, 2012 If you were to fit a set of coilovers with adjustable camber on the top mounts, would these work on a rear beam or would it need independent suspension? Quote Link to comment Share on other sites More sharing options...
Tony Posted March 1, 2012 Report Share Posted March 1, 2012 Would need independent ideally.... Normally when lowered you gain little or no camber so normally we can only back off the front camber... The hub on a beam can be shimmed but it's very expensive. Quote Link to comment Share on other sites More sharing options...
Rich Posted March 1, 2012 Author Report Share Posted March 1, 2012 Would need independent ideally.... Normally when lowered you gain little or no camber so normally we can only back off the front camber... The hub on a beam can be shimmed but it's very expensive. Is this only on the rear you wouldn't gain much camber, so not worth having the adjusters then? Might as well just get EZ bolts on the front to adjust that camber? Quote Link to comment Share on other sites More sharing options...
Tony Posted March 1, 2012 Report Share Posted March 1, 2012 The coilovers will already have adjustable top mounts. Quote Link to comment Share on other sites More sharing options...
adam_r Posted March 1, 2012 Report Share Posted March 1, 2012 The coilovers will already have adjustable top mounts. really ? my old coilovers didnt come with adjustable TM's Quote Link to comment Share on other sites More sharing options...
Tony Posted March 1, 2012 Report Share Posted March 1, 2012 Most do.... If not then it's EZ cam time. Quote Link to comment Share on other sites More sharing options...
