Rich Posted July 21, 2011 Report Share Posted July 21, 2011 I'll remove these where the flexi hose joins the metal piping...do I need to drain the fluid first? Obviously a little bit will come out but I think it will only come out alot when the engine is running and it's pumping it around the system? Quote Link to comment Share on other sites More sharing options...
Tony Posted July 21, 2011 Report Share Posted July 21, 2011 Just crimp the metal brake pipe. Quote Link to comment Share on other sites More sharing options...
Rich Posted July 21, 2011 Author Report Share Posted July 21, 2011 Never thought of that! Quote Link to comment Share on other sites More sharing options...
Tony Posted July 21, 2011 Report Share Posted July 21, 2011 Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 21, 2011 Report Share Posted July 21, 2011 wont that cause a permenet deformation of the metal pipe though ? Quote Link to comment Share on other sites More sharing options...
Tony Posted July 21, 2011 Report Share Posted July 21, 2011 ER i assume we are talking about the Mondeo, if not don't crimp the pipe whatever you do Quote Link to comment Share on other sites More sharing options...
Rich Posted July 21, 2011 Author Report Share Posted July 21, 2011 Yes the Mondeo, obviously I won't crimp the pipe on a car I'm still using!! Quote Link to comment Share on other sites More sharing options...
Tony Posted July 21, 2011 Report Share Posted July 21, 2011 adam_r got me worried for a moment Quote Link to comment Share on other sites More sharing options...
adam_r Posted July 21, 2011 Report Share Posted July 21, 2011 it would have been a good start to civic ownership otherwise! Quote Link to comment Share on other sites More sharing options...
CIH Posted July 21, 2011 Report Share Posted July 21, 2011 LOL Quote Link to comment Share on other sites More sharing options...
Rich Posted July 21, 2011 Author Report Share Posted July 21, 2011 it would have been a good start to civic ownership otherwise! If I was changing the caliper on the Civic I would've clamped the flexi hose Quote Link to comment Share on other sites More sharing options...
Rich Posted August 13, 2011 Author Report Share Posted August 13, 2011 I had a look at the pipes today, where they finish and join the flexi hose they're pointing upwards. Am I right in thinking that no fluid will come out unless I turn the ignition on and pump the brakes? So I might not have to crimp the pipes. Quote Link to comment Share on other sites More sharing options...
SMARTLY Posted August 13, 2011 Report Share Posted August 13, 2011 Doesn't gravity say it will flow down if there is any further up in the pipe? I'm thinking .... | | | | | | | | * * | | * |________| * doh !! It doesn't show it right Quote Link to comment Share on other sites More sharing options...
Rich Posted August 13, 2011 Author Report Share Posted August 13, 2011 Obviously a little will leak from the flexi hose but I would've thought after that the rest will just sit in the pipe as there is nothing pumping it through. What were you trying to draw? Quote Link to comment Share on other sites More sharing options...
Tony Posted August 14, 2011 Report Share Posted August 14, 2011 Gravity will play it's part....... On the caliper bleed nipple ( love that word ) you should have a rubber plug, put that on the pipe to stop the flow. Quote Link to comment Share on other sites More sharing options...
Rich Posted September 9, 2011 Author Report Share Posted September 9, 2011 Well I tried clamping the pipe but it was still weeping out so in the end I snapped the lock screw off and clamped the very end of the pipe to stop it leaking. Quote Link to comment Share on other sites More sharing options...
Tony Posted September 9, 2011 Report Share Posted September 9, 2011 One way to do it. Quote Link to comment Share on other sites More sharing options...
Rich Posted September 9, 2011 Author Report Share Posted September 9, 2011 Even though I clamped the pipe so it looked flat it still wasn't enough, the only way was to pinch the end together. Quote Link to comment Share on other sites More sharing options...
liner33 Posted September 9, 2011 Report Share Posted September 9, 2011 Just put some cling film over the top of the resevoir and screw the cap back on this causes a vacuum so the fluid cant leak out The ignition makes not difference the brakes are hydraulic Quote Link to comment Share on other sites More sharing options...
Rich Posted September 9, 2011 Author Report Share Posted September 9, 2011 Just put some cling film over the top of the resevoir and screw the cap back on this causes a vacuum so the fluid cant leak out The ignition makes not difference the brakes are hydraulic Abit late now but thanks for the tip Quote Link to comment Share on other sites More sharing options...
